How to default Rotel RSP-1068 to 2ch
Old 17-11-2009, 6:04 PM   #1
1,326, Level: 8
Points: 1,326, Level: 8 Points: 1,326, Level: 8 Points: 1,326, Level: 8
Hello,
This is my first post on this forum and I wanted to firstly apologise that its one that is asking for help
I have an LG TV, My Xbox, DVD player and sky box all plug into my TV. I have then connected the TV to my Rotel via Optical this translates to Video 4 on the processor.
The problem is I only have two speakers - I have connected my Rotel to my amp using the two Front R and Front L connectors. When I press the 2ch button on the front of my RSP-1068 it sounds perfect on my system. The problem is as soon as I change the channel or the input on my TV the processor defaults back to Dolby and I have to press 2CH again.
Is there a way of setting this as the default so I don’t have to press it every time I do something on my TV?
I tried to look through the menu but to be honest I can’t even get that to appear. I have clicked menu on my remote but nothing appears on the Rotel and it just says empty on the screen of the remote?
I’m pretty new to this and I know my setup isn’t utilising the Rotel to its full capacity but this is just a temporary setup until I have enough money to get all of my equipment sorted.
Any help would be greatly appreciated,
Old 18-11-2009, 9:42 AM   #2
Jamie's Avatar
10,760, Level: 24
Points: 10,760, Level: 24 Points: 10,760, Level: 24 Points: 10,760, Level: 24
Thanks: Gave 93, Got 573
Re: How to default Rotel RSP-1068 to 2ch
Can you not use the setup menu to set centre and surrounds to off. This way the Rotel will only ever use your 2 speakers. Sounds like the unit still thinks it has the other speakers attached to me.
Old 18-11-2009, 10:05 AM   #3
1,326, Level: 8
sorry to sound ignorant but when i press menu on the remote it just says empty and nothing appears on screen of the device?
thanks
Old 19-11-2009, 12:50 PM   #4
7,884, Level: 21
Points: 7,884, Level: 21 Points: 7,884, Level: 21 Points: 7,884, Level: 21
Thanks: Gave 15, Got 36
I owned a Rotel a few years ago, so I may not be 100% correct, but I think the 1068 needs to be connected by either S-video or composite for the on-screen menu to work.
I'm pretty sure the menu won't work over component.
Hope this helps
Slingshot
Old 20-11-2009, 2:35 PM   #5
7,211, Level: 20
Points: 7,211, Level: 20 Points: 7,211, Level: 20 Points: 7,211, Level: 20
Thanks: Gave 0, Got 6
You need to make a video connection from the Rotel to the TV to see the setup menu. An s-video cable should be fine, (although the menu is available over component, but you neeed to set the mode to progressive, if you are using it).
1 Connect rotel to tv
2 select rotel input on tv
3 press menu - Setup menu should appear
4 select speaker, then follow options to output to 2 speakers (as JimBob said)
5 to make doubly sure, from the main menu, select input, then select your input (Processor 4 I think you said), then in the Default mode menu option, select Stereo).
HtH
Andy
