I currently use a Rotel RSP-1098 as my video processor solution, which looks lovely, sounds just lovely, but doesn't have any HDMI connectivity. So instead, I run my two sources (an Oppo DV-983H and an XBox-360) straight to the screen.
But... I now have more HDMI devices to connect. And I've also been considering an iScan Duo to improve the picture quality of my SD sources.
The more sceptical might say I'm trying to justify using a Duo as an HDMI switch
Question is then, how to set it up with regards to HDMI audio. The Duo has an HDMI audio-only output, which I could connect to an HDMI-endowed av pre-amp. But mine isn't, so I would consider replacing it, either with an Audiolab 8000AP or a second-hand RSP-1069.
Using a Rotel RSP-1069:
+ Inexpensive. Around £400 for a second-hand one, I think.
+ Will match the existing kit and look snazzy.
+ Plenty of old analogue inputs for other kit.
+ Audio management and other features.
- HDMI 1.1 inputs, so wouldn't be able to take DTS Master Audio or TrueHD.
Using an Audiolab 8000AP:
+ Small footprint, which will make some space in my rack for the Duo.
+ Supposed to sound very good musically.
- More expensive at just under a grand.
- Fewer audio managment features.
- HDMI 1.2 inputs, so wouldn't be able to take DTS Master Audio or TrueHD.
I hear that HDMI audio (without video) has significant jitter. However, the Duo's "HDMI audio" output apparently sends a blank 720p video signal with it - hopefully this will mean the clock can be better recovered and hence less jitter (need an expert opinion there!).
I may well run toslink/spdif audio connections to the av pre-amp (either directly or via the Duo) as an alternative if jitter is a worry. But if I'm going to do that, I might as well just not buy a new preamp anyway!
Does anyone have any advice they might offer me?
Rotel RSP-1069 vs. Audiolab 8000AP?
What audio processors do you guys tend to use with video processors?
Thanks!
