| Re: Which Power Amp for next upgrade
Hello,
I'd take a serious look at the Bryston 5B-ST or SST, this is a superb 3 channel amp which is conservatively rated at 150W/ch (they usually measure more like 165 or 170W/ch all channels driven), come with a 20yr transferable warranty, and sound incredibly transparent, detailed and fast without being forward or hard. Certainly not the cheapest 3 channel amp out there (£1,300 - £2,000 used) but I have used Bryston amps in my Hi-Fi and home theater system for the last 11 years and feel no need to look elsewhere even today.
I should mention that at the badaweb site there is a 9B-ST THX (a modular 5 channel amp with 3 channels installed) currently available for £1,650, might be worth checking to see if you can buy another 2 channels for this at a later date and at what price.
The other option (albeit in a very different direction) would be to check out the NuForce monoblock amps, I would suggest the 8.5 v2's if you can find them used (I understand they have now been discontinued) but they are compact, cool running and sound very good, but I wonder if they might be a little incisive with your Mission speakers?
Regards,
Dave
