Pre-pro with older power amps.
| | Post Reply |
| | #2 |
| Senior Member | Re: Pre-pro with older power amps. |
| Quote |
| Thanks from: | KelvinS1965 (27-10-2009) |
| | #4 |
| Veteran Member | Re: Pre-pro with older power amps. Last edited by Mark.Yudkin; 27-10-2009 at 9:13 AM. |
| Quote |
| | #5 |
| Illustrious Member | Re: Pre-pro with older power amps. |
| Quote |
| | #7 |
| Quote |
| | #13 |
| Prominent Member | Re: Pre-pro with older power amps. Last edited by stevefish69; 27-10-2009 at 5:50 PM. Reason: typo :o( |
| Quote |
| | #15 |
| Quote |
| Thanks from: | KelvinS1965 (29-10-2009) |
| | #16 |
| Veteran Member | Re: Pre-pro with older power amps. Last edited by KelvinS1965; 29-10-2009 at 12:28 AM. |
| Quote |
| | #17 |
| Veteran Member | Re: Pre-pro with older power amps. |
| Quote |
| | #18 |
| Member | Re: Pre-pro with older power amps. Last edited by Apollo72; 29-10-2009 at 2:26 PM. Reason: word |
| Quote |
| | #19 |
| Veteran Member | Re: Pre-pro with older power amps. Last edited by Welwynnick; 29-10-2009 at 4:06 PM. |
| Quote |
| | #20 |
| Quote |
| Thanks from: | Welwynnick (02-11-2009) |
| | #23 |
| Illustrious Member | Re: Power amp decision & DIY temp solution. |
| Quote |
| Thanks from: | KelvinS1965 (04-11-2009) |
| Post Reply |
which will probably work out closer to £700 after importing, but that's still cheaper than pretty much everything else
) is to find a good quality secondhand anamorphic lens.
E. & O.E.
LinkBack URL
About LinkBacks
