| Audio Research VS60 and Monitor Audio GS60
Hello fellow members,
I own a pair of Monitor Audio GS60 speakers and am considering buying an Audio Research VS60 power amp.
I'd like to ask your opinion on whether you believe this will be a good match or if there could be any potential problems (for instance, amp not having enough power to drive the speakers, etc...).
The speakers nominal impedance is 6 Ohm and the amp has 4 and 8 Ohm outputs. I guess this won't be an issue, anyway which output do you recommend I'd use?
The Amp and Speakers specs are as follows:
Audio Research VS60
Power output: 50 watts per channel continuous from 20Hz to 20kHz. 1kHz total harmonic distortion typically 1% at 50 watts, below .05% at 1 watt.
Frequency response: (-3dB points at 1 watt) 1.0Hz to 70 kHz.
Input sensitivity: 1.0V RMS Single-ended for rated output. (26dB gain into 8 ohms.)
Input impedance: 100K ohms Single-ended.
Output taps: 8 ohms, 4 ohms
Hum & noise: Less than 0.2mV RMS - 100dB beow rated output (IHF weighted, input shorted).
Power supply energy storage: Approximately 166 joules.
Power requirements: 105-125VAC 60 Hz (210-250VAC 50Hz) 320 watts at rated output, 500 watts maximum, 200 watts at "idle".
Tube complement : (2 matched pairs) 6550C power output, (3) 6H30 input and driver
Other: Remote start: 12VDC at 17mA
Output polarity: Non-Inverting.
Monitor Audio GS60
Frequency Response: 28 Hz - 43 KHz
Sensitivity (1W@1M): 90 dB
Nominal Impedance: 6 Ohms
Maximum S.P.L
(Per pair in room): 112.5 dBA
Power Handling (RMS): 200 W
Recommended Amplifier Requirements (RMS): 60 - 200 W
Bass Alignment: Sealed Mid-Range Enclosure. Dual Chamber Bass Reflex with Differential Tuning (HiVe®II Technology)
Tweeter Crossover Frequency: 2.7 KHz
Bass Crossover Frequency: 150 Hz
Drive Unit Complement:
2 x 6” RST®II bass driver
1 x 6” RST®II mid driver
1 x 1” (25 mm) gold dome C-CAM® tweeter
As for the rest of the components in my system:
- Arcam C-31 Pre-Amp
- Arcam CD-33 CD Player
- Michell Orbe Turntable
Am I prone to running into trouble or is this a safe bet?
I've had an Audio Research Classic 60 running on my system and enjoyed it very much.
Your opinion is highly appreciated!
Thanks & Regards to all,
Gonçalo
