Arcam p7 problem
Old 16-10-2009, 10:37 PM   #1
6,431, Level: 19
Points: 6,431, Level: 19 Points: 6,431, Level: 19 Points: 6,431, Level: 19
Thanks: Gave 3, Got 1
Arcam p7 problem
What's the point in trying to choose a new preamp when your power amp stops working?
Hopefully someone can help - all the lights on my p7 keep going red with one flashing orange - no sound - any ideas of what is wrong, the solution and cost?
Many thanks
Old 17-10-2009, 12:33 AM   #2
MI55ION's Avatar
15,074, Level: 29
Points: 15,074, Level: 29 Points: 15,074, Level: 29 Points: 15,074, Level: 29
Activity: 8.3%
Activity: 8.3% Activity: 8.3% Activity: 8.3%
Thanks: Gave 400, Got 355
Re: Arcam p7 problem
As per manual:
LED status
During power up or normal operation, one LED is flashing amber, with the remaining LEDs solid red
Description
An over temperature fault has reoccurred on the same channel within 12 seconds of a previous over temperature fault clearance.The flashing amber LEDs represent the amplifier modules with an over temperature fault.
Amplifier action
The amplifier shuts down. The power switch must be cycled to reset the amplifier (cycling the trigger resets the amplifier).
Hope that helps.
Old 17-10-2009, 5:45 AM   #3
6,431, Level: 19
Yeah, I confirmed that side of the amp was very hot, but what caused the overheating and is this something permanent? Van this happen as a one off incident and then be okay do u know?
nic
Old 18-10-2009, 8:42 AM   #4
Mark.Yudkin's Avatar
16,391, Level: 30
Points: 16,391, Level: 30 Points: 16,391, Level: 30 Points: 16,391, Level: 30
Activity: 29.1%
Activity: 29.1% Activity: 29.1% Activity: 29.1%
Thanks: Gave 33, Got 1,037
First off, check that there are no stray strands of speaker wire that could short the channel. Check both the amp and the speaker ends.
Do you have the recommended clearance around the P7, and is the amp in a well ventilated location, e.g. not in a closed cupboard?
If it happens again, get the P7 repaired. If you're lucky it's still under guarantee (you have 5 years).
