| Re: Octava HDS7A-UK -any opinions?
The DTS soundtrack on The Dark Knight via optical sounds much better than the uncompressed TrueHD soundtrack via the Octava. The Octava is lacking any bass at all, and it sounds very chesty and dull. No top end, no bottom end.
Now bear in mind that I have my AV2 set to Large for all speakers, so I'm used to feeding them a full range signal. The Octava via multichannel does seem to have more dynamics to the sound, as you'd expect from uncompressed audio. As Batman lands on the van in the carpark there's a much more punchy thump, but with my kit, at least, this doesn't sound great at all. There is just no low or high frequency content getting to the fronts.
Intriguingly enough, the Octava ships with a little leaflet as well as the handbook. It says, and I quote, 'Your unit has been installed with all the firmware necessary. There is no need to install these ICs before use. Optional: In the event of compatibility issues, you may install the 2 chips attached. It should solve some common issues'. Yes folks, it comes with 2 small chips that you can install yourself! I'm not going to try these because it will void the warranty and I'm not sure I['m going to keep this unit given the performance so far. Definitely the first time I've ever seen chips supplied with a purchase though.
In summary, I guess I was asking a lot to expect a £250 box to approach the sonic performance of the converters in a £2500 processor, but I am still disappointed in the sound from this box. It could be that the AV2 isn't handling the multichannel signal properly, or that the PS3 has a setting I'm missing. Either way this was not the exciting audio experience I was looking forward to.
Anyone had better luck? I know these get modded for Meridian kit so I can't believe this is all there is....
