BOUYER AR1150 & Pa 1150
| | Post Reply |
| | #1 |
| New Member | BOUYER AR1150 & Pa 1150 Advertisement Want to Advertise?
Hi all!!! OK I have never heard of Bouyer to be honest but was given 2 units, AR 1150 & PA 1150, the units are seperate but can be merged together via a connection on the bottom of the PA unit. They are very heavy & since I dont know what they are or have any use for them as they dont even have speaker terminals but PA type speaker connections I want to sell them. I contacted Bouyer to get a price but they said the units are discontinued, so I was wondering if any1 knew how much they could go for, they are 2nd hand , working, no marks or scratches. AR These 50W, 100W, 150W and 180W amplifiers may be used on the mains or battery for safety duties. They are built in 19Ó half format; two units can be assembled side-by-side, taking up less space. These units have the tone correctors and light indicators required for optimal use. II - TECHNICAL SPECIFICATIONS ¥ Output powers (RMS) 50 W - 100 W - 150 W - 180 W (in accordance with model) ¥ Distortion .................................................. ..< 1% ¥ Bandwidth (-3dB) 65 - 20 000 Hz .................... for the AR1050, AR1100 and AR1150 75 - 20 000 Hz ......................for the AR1180 ¥ Tone control Bass ..........................................±8 dB at 100 Hz Treble ........................................±8 dB at 10 kHz ¥ Signal/noise ratio (unweighted)...... ³80dB ¥ Input................ 0dB balanced 10k½ (transfo) ¥ Outputs Line ................0 dB balanced parallel at input Low imp.dance ............................................4 ½ High impedance 70 V 100V AR 1050 100 ½ 200 ½ AR 1100 50 ½ 100 ½ AR 1150 33 ½ 66 ½ AR 1180 27 ½ 55 ½ ¥ Power supply mains ............................ 230V+terre 50/60Hz battery .................................................. .. 20-32V ¥ Consumption °(in accordance with model) mains ..................110 / 200 / 300 / 460 VA battery .................................. 3 / 5,5 / 8 / 10 A ¥ Dimensions ....212 x 325 x 135 mm (Fig. I) ¥ Weight ..............................6 / 8 / 8,8 / 9,3 kg ¥ Rack 19" mounting with set handles AZ 8 (Fig. II). ¥ Options AZ 1330 : amplifier fault detection board for AR 1050, AR 1100 and AR 1150. AZ 1310 : amplifier fault detection board for AR 1180. AZ 8 -Handle set for rack mounting ¥ Feature Cooled by fan with thermostat. PA The PA are modular 50W, 100W and 150W mono mixer amplifiers which are powered by the mains or by battery for use in safety applications. They have 4 emplacements for inputs and outputs which can be adjusted individually. Each one can be adjusted individually. Bass and treble can be set by using the dedicated buttons on the front panel. By adding fault detection board, the amplifiers may be supervised. The PA can be mounted in a 19” rack by using handles AZ 8 (option) (Fig. II). II TECHNICAL SPECIFICATIONS • Output power (RMS) (in accordance with model) 50W - 100W - 150W - 180W • Distortion........................................ ....< 1% • Bandwidth (-3dB) ................75 - 17000 Hz • Tone control Bass....................................±8 dB at 100 Hz Treble..................................±8 dB at 10 kHz • Unweighted signal/noise ratio : (depending on the module used) : AZ 1210 ..........................Mic input ³ 60 dB Line input ³ 60 dB • Inputs : ......................................4 modules + 1 balanced direct line 0 dB • Outputs : Line........................................0 dB balanced Low impedance ......................................4 W High impedance ........................70V - 100 V • Power supply mains ........................ 230V+earth 50/60Hz battery........................................... ... 20-32V • Consumption : mains ....................120 / 210 / 310 / 460 VA battery ................................ 3 / 5,5 / 8 / 10 A • Dimensions......425 x 345 x 135mm (Fig.I) • Weight ....................9,5 / 10 / 11,5 / 11,5 kg THANKS |
| Quote |
| Post Reply |
E. & O.E.
LinkBack URL
About LinkBacks
