Does anyone have the Rotel 1570/1575?
Old 22-07-2009, 1:09 PM   #61
paulst10's Avatar
Thanks: Gave 534, Got 1,160
Re: Does anyone have the Rotel 1570/1575?
John, has it arrived yet ?
I am gutted about the Parasound and have been considering just buying a new power amp what's the warranty on the 1575 ?
Old 22-07-2009, 1:44 PM   #62
saguk1234's Avatar
Thanks: Gave 111, Got 114
One year.
Old 22-07-2009, 4:51 PM   #63
paulst10's Avatar
Originally Posted by saguk1234 View Post
One year.
Is that all ? I even got a 3yr with my Onkyo
Originally Posted by recruit View Post
yep, need to calibrate it now
Looking good mate, so how does it sound ?
Old 22-07-2009, 6:10 PM   #64
saguk1234's Avatar
Yeah but with an Onkyo you need as many years as you can get but Rotel are much more reliable!
Old 22-07-2009, 6:13 PM   #65
Apone's Avatar
Thanks: Gave 324, Got 205
Keep us posted on how it sounds with the S150's compared to the 875
Old 22-07-2009, 9:03 PM   #66
saguk1234's Avatar
The blue light stays on regardless if the amp is on or not. Same with the processor. The red light comes on when the amp is off. This seems like normal operation to me.
Old 23-07-2009, 6:03 PM   #67
paulst10's Avatar
some more pictures of the 1575...
Certainly one good looking bit of kit this
Old 23-07-2009, 7:04 PM   #68
Thanks: Gave 44, Got 18
Had some serious listening today, and this is a very nice poweramp indeed, will post some opinions soon, lets just say for the money it is very good indeed...
Certainly sounds like serious competition for heavyweights such as the very expensive Bryston 9BSST.
Old 23-07-2009, 8:25 PM   #69
Thanks: Gave 14, Got 136
Has anyone opened the case yet to see for certain if it has oem digital amp modules in or not as Rotel seem to claim.
Just interested.
Old 23-07-2009, 11:38 PM   #70
Conspicuous Member
Russell.Williams's Avatar
Thanks: Gave 759, Got 1,581
Forgive me for asking this, but just how bright is the blue light? I mean, can you turn the everything else off and still see your way to the door?
As you know, I get easily miffed by such details.
Russell
Old 24-07-2009, 7:33 AM   #71
Medrep1's Avatar
Thanks: Gave 110, Got 72
I heard on HTGUIDE Rotel may or already have released some form of sticker or diffuser thingy to cover the light?
This was supposedly from customer feedback?
Check out Rotel section on that forum, there is a lot of news there that seems to appear before here?
It is bright btw, too bright.
Old 24-07-2009, 7:52 AM   #72
saguk1234's Avatar
I read that someone has opened both units and disconnected the lights.
Old 24-07-2009, 12:00 PM   #73
For anybody interested I think they are ICEPower 500 ASP modules in the amp.
Old 24-07-2009, 12:42 PM   #74
Thanks: Gave 616, Got 766
It looks like it uses exactly the same configuration as the highly regarded NHT Power 5 amp, with two 500ASP modules and three 500a modules. The large ASPs have the power supplies, and these are shared around the integrated and separate amplifiers.
The NHT was a powerhouse - do a search for reviews.
Nick
Old 24-07-2009, 11:33 PM   #75
Illustrious Member
Smurfin's Avatar
Thanks: Gave 785, Got 1,223
Recruit, your photos aren't showing for me?
Old 25-07-2009, 11:28 AM   #76
M3M M3M is offline
Thanks: Gave 0, Got 3
So is everyone with a 1570 using HDMI for audio?
Old 25-07-2009, 4:37 PM   #77
saguk1234's Avatar
I am.
Old 27-07-2009, 1:15 PM   #78
saguk1234's Avatar
Recruit,
How is the amp?
Old 29-07-2009, 3:16 PM   #79
Conspicuous Member
AngelEyes's Avatar
Thanks: Gave 384, Got 964
Jumping ship John?
Adam
Old 29-07-2009, 3:39 PM   #80
saguk1234's Avatar
Taken from a post somewhere else:
Now I have owned this amp for nearly a week now and luckily enough plenty of time to play and listen to how this new power amp performs, just some back ground to what I have owned and listened to in the past, I have owned quite a few Pre/Pro Lexicon / Meridian / Parasound and a few high end Integrated AV amps and more or less settled on an all in one solution as I felt that the performance gains were minimal when running the speakers that I own, which are M&K S150THX speakers and crossed over at standard THX recommendation of 80Hz, so all the low end is taken care of by the sub, this takes a lot strain away from the amp and therefore THXUltra2 spec AV amps have no problems powering them, and this has worked well with great results and superb movie performance.
The new ROTEL RMB-1575 comes in 2 finishes Black and Silver with black being my preferred colour, as in most Home Cinemas black can disappear when dark much easier, although the silver is a lovely finish too, and if you have your kit on show then it certainly does do justice to your system and credibility on looks, the only negative point on the looks is the power button which has a seriously bright blue halo affect light around it and when on it can be quite distracting, I think this will annoy quite a few people with light controlled rooms, this is just a small negative point though and can be resolved by covering the button or hiding away in the AV rack, the rest of the amp is finished to a very high standard and certainly looks high end, at the back of the unit you get unbalanced connections and a 12v trigger switch so can be linked with a processor to power on, they have omitted balanced connections and this obviously keeps costs down but tbh I do not see this as a problem as most connections are RCA anyway and only really require balanced when long runs are required, the binding posts are of high quality and gold plated connectors are used for them and the RCA too.
Image hosting, free photo sharing & video sharing at Photobucket
The amp comes in at a relatively low weight of 11kg which for amps is featherweight compared to others, I have owned Lexicon and Parasound in the past and they are very heavy compared to the ROTEL, the reason for such light weight is down to this amp being class D which is also known to some as Digital, and I believe this is the first multichannel amp for ROTEL to use this technology and for most hifi audio purists this is frowned upon, with class A/B being the common and widely used amps of choice.
Power wise this amp has huge amounts and is rated at 250watts into 8ohms and a staggeringly high 500watts into 4ohms, and considering its weight is quite hard to comprehend as usually for this sort of power you are looking at 30kg plus!
Moving on swiftly to the most important part and that is the audio performance of the 1575, I have a lot of material for use and also quite a few sources to play with, BD and DVD is taken care of by the superb Oppo BDP83 and this is considered by many as a reference player which also is the first universal player and SACD / DVD-Audio can be played too, I own lots of these with preference being DVD-Audio for audio playback and also CD, I am using an HTPC for movie use too but can only use LPCM and standard DD & DTS on the HTPC, I am using the Onkyo 905 AV amp as my processor and it can handle all the new HD audio formats and also SACD DSD and LPCM for DVD-Audio and the usual vanilla flavours DD + DTS.
My first selection of films I watched were ones that I am quite familiar with, these are Titan AE and the Incredibles on DVD, I am used to watching these films as they have cracking sound mixes with lots of LFE and effects galore, the ROTEL really did do them justice and the sound was string tight and effects moving swiftly around my 5.1 setup and it did not feel strained at all with my Onkyo playing at -5db, it was not fatiguing and no hardening of the sound at this level, I felt that the Onkyo did not quite match this amp at these levels with the Onkyo possibly sounding strained compared to the brute 1575.
Most of my listening is with the new BD format and these containing both Dolby True HD and DTS HD MA soundtracks, now with these formats the soundtracks are lossless which is considerably higher bitrates than the standard compressed DD + DTS tracks and therefore they are more dynamic in nature, this is where I was quite literally staggered at the difference this amp does make to the sound and with 2 movies that I really enjoy watching are the Dark Knight and Iron Man which have incredible sounding mixes, my M&K’s really did come alive and the soundstage was huge with panning and effects really jumping out at me, explosions were so much more composed with the speakers starting and stopping at lightning quick levels, I just sat through these films with a huge grin on my face and quite shocked at how much difference this amp has made and just shows how good the new lossless soundtracks are in comparison to DD+DTS, it’s not to say that DD+DTS are not good enough just that the differences with the power amp are less profound.
Luckily my love for audio is not just based on movies but for music too, and at last I have back in all its glory DVD-Audio and SACD since owning the Oppo universal player and my big collection have had a new lease of life, and once again the ROTEL power amp has boosted the performance and listening pleasure that these high resolution discs offer, again the soundstage is a lot larger than before and the music has more rhythm than the Onkyo could offer before it and subtlety’s in detail coming through and my S150’s do actually play music quite well and my feet were tapping to the music, it is so good that I just keep on ordering new discs!! So not so good for my wallet.
I think I shall stop here as I have rambled on for some time now but my closing thoughts for this Power amp the ROTEL RMB-1575 which retails for approx £1700 is that it is an absolute bargain and certainly shows what a digital amp can do, it has oodles of power which does not get hot and is dead silent in its operation, I can also say that if you are looking for a new power amp then this is more or less the perfect choice!!
Old 29-07-2009, 4:00 PM   #81
saguk1234's Avatar
Its an absolute beast of an amp! I love it. This is a keeper. Hopefully the high end processor to the 1570 will come out in Christmas!!
Old 29-07-2009, 6:22 PM   #82
blueye's Avatar
Thanks: Gave 22, Got 19
s
what high end processor @ xmas are you talking about?
Is there a new one in the pipeline?
Regards Blueye
Old 30-07-2009, 8:18 AM   #83
Mr_Orange's Avatar
Thanks: Gave 137, Got 251
Isn't it the replacement for the 1098?
Old 30-07-2009, 8:56 AM   #84
saguk1234's Avatar
Yes thats it.
Old 02-08-2009, 6:16 PM   #85
AvLee's Avatar
Thanks: Gave 18, Got 18
Only just seen this thread, interesting read.
I'm actually on the look out for this combo in Silver if any of you guys get bored and fancy something else?
My thread here: http://www.avforums.com/forums/ampli...er-wanted.html
My only worry is, how the amp will cope with 4 Celestion A3's...as there's talk of clipping a few pages back....
Has anyone tried the RSP-1570 with the older RMB-1095 amp?
Old 03-08-2009, 12:23 PM   #86
AvLee's Avatar
Yep, I know they're still quite rare 2nd hand atm moment, I did see Saabtech's one for sale a while back but it was black.
I have heard talk of getting the combo for £2300 new, I haven't had a proper "price check" look around yet.
Old 05-08-2009, 7:55 AM   #87
AvLee's Avatar
I'd say can possibly get at least 20% off the RRP
Old 05-08-2009, 6:24 PM   #88
paulst10's Avatar
One year.
According to Rotel website, it states all come with 2yr warranties Home Theater System Surround Sound Amplifier DVD Player - Rotel Frequently Asked Questions
Rotel Amplifiers, integrated amplifiers, pre amplifiers, processors, tuners, receivers, line conditioners, and switchboxes:
2 years parts & labor.
That's a bonus for anyone who thinks they only have 1yr
Old 08-08-2009, 9:01 AM   #89
Medrep1's Avatar
The new speakers I have upgraded to are very power hungry. They sound magnificent as they are with the 1575, but I know more can be squeezed out of them. I have had the amp clip at high (too high tbh) levels which tells me the speakers are asking for more
My cyrus CD8 has given up the ghost yet again, **** cyrus!
Anyway, had the denon 3800 as a cd player via analogue and had some well known music cranked right up, almost to 90 on the 1570. The x3 Rohacell bass drivers on the 803D's were slapping away like ive not seen before, and the amp didnt clip? I dint have the balls to turn it up more, especially as it was 9am
Very confused now? Im going pull everything out again and rewire and check connections, it may have been coincidence but seen as I have been told my dealer and other owners of the new 15 series pre/pro its unusual for the amp to clip?
I will have a play and let you know?
Last edited by paulst10; 08-08-2009 at 11:30 AM. Reason: Please do not circumvent the swear filter
Old 08-08-2009, 11:31 AM   #90
paulst10's Avatar
I have been using mine this week at very loud levels roughly -3db on the 905 and no signs of strain on the amp, it does go very loud and my M&K's lap it up, they are no way near as demanding as the 803D though, I wish all my components were as efficient as the ROTEL amp, everything else runs so hot but not the 1575
on a side note, I have owned over the years lots of cyrus kit and not once did they go faulty, I have owned the 7 series / 8 and even X series, I would make sure that you check all your wiring incase you have a short somewhere which may be causing damage?
Does the 905 still run hot then even though it's not using the amp stage ?
