AVR600 Initial impressions
Thread Closed
Old 09-02-2009, 9:02 PM   #1
Thanks: Gave 27, Got 188
AVR600 Initial impressions Part I
I have now had an AVR600 for a few days. Normally this wouldn't be long enough for me to be able to fully opine on a piece, but the 600 was so easy to use that I got the maximum benefit from my time. Being familiar with Arcam was a great help here. Everything in this review is my own opinion and direct experience, some others may have a different experience, as their requirements may differ greatly.
Before anyone gets on my case here, issues with the unit will be dealt with in the second part.
The following headings are in no particular order.
1.Overall sound quality.
Quite simply, this unit is sonically stunning. It is a major leap forward for Arcam in many ways, I'll touch on them as I progress. The imaging is impeccable, and the unit is easily capable of gossamer light delicacy or some serious sonic violence, depending on what the source demands. I would say it has a surgical clarity that I've never heard in a receiver before. The best sounding receiver prior to this was the 350, but the 600 is well ahead of that. £3k may be expensive for a receiver, but for an audiophile unit that kind of money is small potatoes indeed. This unit, when coupled with good speakers and in a room that has been properly treated and corrected, is capable of serious audiophile quality reproduction. More on the test systems later, but they form 2 pairs of systems..... a Linn Akurate and Dynaudio Contour, both using Gotham subs, and the colossal Dynaudio M4 and Genelec 1036a, both using HTs6 subs.
2. Ease of use.
Nothing much new to say here. Its well laid out and organized. The menus are very easy to follow and logical to use. Its connectivity is amazing and very flexible indeed. The sources that are audio only, like TAPE, can have a video feed assigned to it. As an example, it takes seconds to have an HDTV video feed coupled with an internet radio sound source.
Things like disabling HDMI audio on specific inputs works fine too, so satellite users will be happy there. The Networking is set up in an instant and the internet radio is very easy to use and personalize. All the VP settings are "per source" as are things like room EQ and processing modes. 7.1 users who need PLIIx can set the unit such that it will always engage if there is a 5.1 signal, no need to select it. Spend some time with this unit to set your options as you wish and you will find that the unit simply begins to disappear, you don't have to work at it. All adjustments are shown as on-screen pop ups, this can be disabled if you wish.
3.Auto adjustment.
I'm not a fan of automated set-up and room correction. I am a correction fan, but prefer the use of systems like the Dolby Lake as they are vastly more flexible and provide markedly superior results. I was, however pleasantly surprised. The system fires a broadband noise burst from each speaker, it does 2 rounds then does its calculations. I found, in the 3 rooms I tried, it got the speaker distances spot on. They were within an inch of the actual measured distances. The crossover frequencies listed for each speaker looked reasonable too (there is one master crossover). The speaker levels were also close to ideal. when testing is done you can see all the results, you then select "accept" to store those values. You can adjust them manually later anyway, if need be.
The other part is the Room EQ. Even when you select "accept" as above, the room EQ is not applied by default. This is a good option, as it means you can still use the other measurements. The room EQ can then be selected, or not, for each individual source. The analysis looks at the broadband noise through the calibrated microphone and tries to even out any room resonances you may have.
The first room I tried was well treated, and had good geometry. Engaging the room EQ made a small but noticeable difference, but not near as good as the system already there, that was as much as I expected anyway. I certainly didn't do any damage. The second room was smaller and is awaiting treatment, the improvement was very noticeable indeed. Switching the EQ repeatedly in and out revealed a number of changes. Fidelity was improved, separation and fine detail was better and vocal ineligibility was improved. Delicate ambient sounds like rain or crickets were far better. Obviously the difference is source dependent, if the source doesn't impinge too much on the problem areas, the difference will be less apparent.
I would urge anyone to take the 5 minutes to run an analysis and see how the room correction works for you. If you don't have an SPL meter and tape measure, you will at least have a decent start point for distance,level and crossover.
The software is by Analog Devices, the guys who provide the SHARC DSP chips. They are very well known in audio circles.
4.Video processing.
More than anything, I simply wanted to see a transparent pass through, ie when no VP functions are selected. The seems to be the case here.
There is actually a fair bit going on under the hood here that may not be immediately apparent. I'm happy to report that I didn't encounter any nasty surprises. I use 1080 sources almost exclusively, but had a look at some other resolutions to test the scaling clarity. No problems at all. On close inspection, it scales SD-DVD better than the 360, PS3 and a satellite box so it will have it uses. The contrast, brightness and color all work as expected. Noise reduction is more interesting, and yielded some minor improvements with noisy SD material. The normal types are represented here. There is an Edge Enhancement feature too. This has no place with good source material, but did yield a reasonable result with some soft sources, picking out some extra detail. With good stuff, it just looks crazy. People end up with faces that look like they have some serious skin disorder. Every pore looks like a mine shaft.
I have no use for the VP as I use native processong. Others may differ and benefit from making some "per source" adjustments to the big 3...Brightness, Contrast and Color.
I have no issues whatsoever with the neutral passage of 1080p24. Just make sure you select Auto in the frame rate pull down.
Thats the first part done. I'll try to do the other half tomorrow. I will look at surround performance, legacy AV9 head to head, issues and resolutions, Dolby Volume, network use, etc.
Hope this helps and is of interest.
acave (09-02-2009), cannondale99 (11-02-2009), cdnxpat (10-02-2009), dalethecaptain (09-02-2009), Dankeech (11-02-2009), FrancescoNoir (09-02-2009), GlennC (10-02-2009), hrotti (21-04-2009), ianmacd (10-02-2009), imightbewrong (19-05-2009), jamesl01 (09-02-2009), Janibrewski (16-02-2009), macros57 (23-02-2009), michels (10-02-2009), Most_Wanted (20-02-2009), Mr X (12-02-2009), Nic Rhodes (14-02-2009), PaulWilliam (10-02-2009), rded (13-02-2009), reaper12 (09-02-2009), ritchief (11-02-2009), sapper (20-06-2009), Starred (10-02-2009), supernaut (11-02-2009), Szadzik (05-08-2012), Turtles (09-02-2009), williamtassone (22-06-2009), x86root (10-02-2009)
Old 09-02-2009, 9:02 PM   #2
Re: AVR600 Initial impressions
AVR600 Initial impressions, Part II
Before I get into part 2, let me address something I should have earlier. Scaling.
Scaling in the AVR 600 is actually very good. Using the test patterns in DVE, it provided better results than my Toshiba XE1. It also seemed to be on a par with my Oppo 983, which is regarded as the benchmark of players. I'd say, for a receiver, this is a home run. Couple that with the ease of use and Arcam hit it out of the park.
Network use.
Very simple indeed. Connect up an ethernet cable and that's it. I didn't even have to power cycle. The 600 immediately found my 2 PCs and the NAS drive.I also connected a Linn server and after a power cycle it was there and its music available. Using a switching unit I allowed the 600 to tap into my "whole house" distribution system. It found the Kaleidescape servers and was unable to access them, this is exactly as it should be.
Internet radio was already there and very easy to use. There is a huge selection of stations available. I quick visit to a PC with an ID number, direct from the menu, gives you access to the Arcam radio page. This allows you to set up your favorites, name your own genre folders etc. You can also import your own URLs. On the subject of subscription radio, not every format is supported, but I will be onto Arcam regarding that. With the networking I wss initially thinking "this is way too easy". All in all a superb network implementation, and pretty idiot proof.
Dolby Volume....updated
For what little I will write, I spent hours familiarising myself with this and the effect it has on sources. Initially I thought it was horrific, this was primarily due to a factory default setting being set to "insane".
Dolby Volume sets out to achieve 2 things.
Firstly, to balance volume between various program material and different sources. Secondly, to retain the volume perception across the spectrum when volume is decreased. After spending time with this, I was able to obtain outstanding results. In the main, it achieves what it sets out to. I recommend the following
1. Dont bother with the "music" preset.
2. Disable the "Dolby Leveller", as the compression sucks the life out of dynamic material
3. Use the offset to obtain a balance between "Off" and "Cinema".
Audio Testing
This is where the rubber meets the road. Who will be gnashing the teeth and shedding the tears? Firstly I just want to make it very clear that I am in no way interested in any arguments that may arise from my observations. My description of the tests may lead the reader to think that theses tests were carried out in a very short space of time. It actually took 2 people large parts of 3 days and is the main reason for the delay in this part of the test. I cant go into too much detail as the report would run into pages and pages.
The test systems were basically 2 pairs of setups. The first comprised stereo pairs of Dynaudio M4+ and Genelec 1036A monitors. These are very large, very powerful and very accurate quad amped (in the case of the Dynaudio) monitors. The Genelecs are Active tri-amped with each amp calibrated to its driver. 2 Genelec HTS6 subs took care of the bass duties. These 2 systems are dynamic and analytical way beyond that of the normal domestic speaker. The tests were run on the Dynaudios then the Genelecs.
The other pair of systems was a Dynaudio Contour 7.1 arrangement and a Linn Akurate 7.1 system. These are a more reasonable system for a smaller room and would give a good indication of what would be possible in that sort of environment.
I went to the monitors first with a number of sources. I used a Sonos, Apple TV with lossless content, in addition to a CD and SACD transport. Both of the latter were of audiophile quality.On each test we used a matrix switcher so that we could switch instantly from an AV9 to the AVR600. Time prevented us from testing with the Halcro I had hoped to. Next weekend I will run brief tests against the Pioneer Susano LX90. The tests were run in pairs ie Test 1, source 1 and source 2. I sat in the money seat and couldn't see what was going on, The pairs were random and were sometimes the same source. Other than internet radio, the same segments were repeated. this test was carried out in direct mode.
I should say, at this point, I am an owner of 2 AV9s and find it to be a great processor.
First we ran the Sonos with some good quality internet radio (256k and 192k). The tests were done fairly quickly and offered a sequential alteration between sources. I marked down the source that I preferred and why, over a number of runs.This type of test was repeated for Apple, CD and SACD. I took a number of breaks to avoid the ear fatigue that blights critical listening tests.The findings are a result of literally close on 200 runs. I will round the results to the nearest 5% in each case.
In 20% of cases I couldn't tell a difference. Many of those were actually the same source repeated, so I wasn't far off. In the 70% of cases where I could hear a difference, the processor I selected as superior was the AVR600. The sound was simply more detailed with a good bit more separation in the soundstage. Snare cracks and fret noise were better defined, brass had more of its metallic edge. Dance music was incredibly detailed too. It was noticed that the higher quality the source, the easier it was to identify the units more accurately.
A similar regime was used to test surround processing. This time it was the AVR600 as a receiver with the AV9 partnered with a P7. For HD codecs the the AV9 obviously relied on its analog inputs. Sources were the Denon 3800BD for Blu Ray and the Toshiba XE1 for HD-DVD. I was able to hear a difference in 75% of cases. Of those cases 75% were the AVR600. Thats a ratio of 3:1. The sound was more detailed, with effects being localized better when appropriate.Panning was smoother, with the transition to rears being seamless. There was also just that overall sound quality that transfers over from the 2 channel tests.
I have also been made aware that those responsible for voicing the AVR600 actually find it better than the AV9.
I will add this caveat to all the above....Bear in mind the speaker systems that were in use during testing, there is a great range of speaker sonic performance capabilities.
Issues and resolutions.
There are a number of issues with the 600 of differing levels of concern. The 600 is possibly more DSP intense than previous receivers. That also means that some issues can easily be fixed with a firmware update. The list below is not meant to be exhaustive or authoritative.
1. PLIIx would not engage properly........................................Fi xed
2. Intermittent 5.1 streams being played as 2.0 with no center....Fixed
3. Gain jump on deselection of room EQ...................Confirmed Fixable
4. Clicks and pops..........................Fault confirmed and given priority
5. Time to sync audio..........................................Bei ng looked into
I hope this helps any reader further understand the AVR600.
I will be making another post just to tidy up any topics I may have forgotten and to address any current or future issues.
Last edited by coldmachine; 06-05-2009 at 8:22 PM. Reason: updated Dolby Volume info
a1000bhp (01-03-2009), avlava (17-03-2009), BENN0 (18-03-2009), Dankeech (13-02-2009), GlennC (13-02-2009), ianmacd (13-02-2009), Janibrewski (16-02-2009), macros57 (23-02-2009), michels (13-02-2009), Most_Wanted (20-02-2009), Nic Rhodes (14-02-2009), rded (13-02-2009), sapper (20-06-2009), stephenc (14-02-2009), Szadzik (05-08-2012), Turbo Tony (20-05-2009), vistisen (13-02-2009)
Old 09-02-2009, 9:49 PM   #3
Thanks: Gave 1, Got 12
Great review, coldmachine!
Old 09-02-2009, 11:12 PM   #4
Thanks: Gave 13, Got 538
good stuff...I just wish theyd hurry up and bring one out without the built in amps I dont need !
Old 09-02-2009, 11:14 PM   #5
Thanks: Gave 8, Got 20
Thank for the review.
Has to be said though, not many will be using genelec monitors at around 20k per monitor.
Old 09-02-2009, 11:16 PM   #6
Thanks: Gave 109, Got 126
Yeah nice work. Interesting read and look forward to seeing the rest of it
Old 10-02-2009, 12:45 AM   #7
onthebeach's Avatar
Thanks: Gave 51, Got 27
Great review coldmachine. Thanks for keeping it simple and easy to understand. Not all of us have degrees in AV science.
Looking forward to some direct comparisons to the AV9 as well as how it goes head to head with other receiver flagships particularly Denon and Yamaha.
Old 10-02-2009, 12:46 AM   #8
Thanks: Gave 28, Got 222
Looking forward to the AV9 comparison. Btw its Sharc not Shark ones a DSP the others in Jaws.
Old 10-02-2009, 9:03 AM   #9
Thanks: Gave 11, Got 2
Is it this one?
http://www.analog.com/static/importe...rrection&la=en
Old 10-02-2009, 10:03 AM   #10
Thanks, brain was on auto-pilot.
Old 10-02-2009, 12:36 PM   #11
x86root's Avatar
Thanks: Gave 54, Got 19
Post Re: AVR600 Initial impressions
Thanks Coldmachine for spending the time to compile a very useful post.
Anyone looking to upgrade an Arcam receiver (Or any for that matter) I say get your wallet out and order an AVR600 instantaneously.
Old 10-02-2009, 1:33 PM   #12
Thanks: Gave 24, Got 8
Thats the first part done. I'll try to do the other half tomorrow. I will look at surround performance, legacy formats, AV9 head to head, issues and resolutions, Dolby Volume, network use, etc.
Comparison with AV9 will be stern test for the processor part of the AVR600.
How can the amplification be tested seperately / compared with a P7 as presumably any sound has to go through AVR600 sound processing first before amplification? Though the difference in quality v the AV9 can be taken into consideration when doing the comparison with the AV9 / P7 combination.
I'm getting interested in this now. I never thought I would go back to a combined processor / amplifier. The AVR600 may make me change my mind.
Old 10-02-2009, 2:41 PM   #13
Thanks: Gave 50, Got 25
I'm also interested in how good the preamp stage of the AVR600 is. How good is the stereo performance of the AVR600? How does it compare to the AV9?
Old 10-02-2009, 3:22 PM   #14
Conspicuous Member
Mark.Yudkin's Avatar
Thanks: Gave 37, Got 1,207
Ron: you asked recently about the AVR600 price over here. There are apparently two versions. Plain: CHF5990, DAB+: CHF6200. Given the UK pricing (and the lower local VAT) it is apparent that the local pricing is based on a rather inflated exchange rate .
Old 10-02-2009, 5:10 PM   #15
Thanks Mark, I saw that. Are you going to go and listen to the AVR600 ?
Old 10-02-2009, 5:15 PM   #16
Thanks: Gave 83, Got 302
Great review Coldmachine.
Despite the reported issues, I'm rather impatient to receive mine now!!!
Old 10-02-2009, 7:37 PM   #17
Thanks: Gave 4, Got 9
I was lucky enough to hear the AVR600 today at lunch and all I can say is wow!
The sound quality was amazing, in fact it was so good I had to leave the shop otherwise I would have ordered one there and then (damn redundancy and recession). Anyone who is lucky enough to own one of these should be very proud of their purchase, from what I have seen and heard it's simply an astounding piece of kit. Well done Arcam
Old 11-02-2009, 7:23 AM   #18
Thanks: Gave 1, Got 0
Does this need an amp to power speakers like Paradigm Studio 100s and Paradigm 690 cc? I'm only doing 5.1....just not sure if the AVR600 will power all that or if I need an amp, even a smaller 2 channel one....
This will be for 100% theater....
Thanks, and keep the feedback coming from those that have got one. I'm supposed to get mine next week, and wonder if I should be concerned about the audio delay when pausing/fast forwarding TV or Blu-Ray....or about the snap, crackle, and pops when changing inputs....
Help?!!?!
Old 11-02-2009, 7:49 AM   #19
Conspicuous Member
Since my speakers (as well as the P1000) are there to stay, I won't be buying an AVR600 and it would be very unfair on my dealer to organize a home demo when I have no intention of buying.
Since I'm not all that sure than any receiver - even one by Arcam - has the power amplifiier stability to drive my speakers, let alone any possible Martin Logan replacement (nominal 4 Ohms, minimum 0.7 Ohms) for the Quads, a dealer demo using his relatively benign dynamic speakers (such as mookie's Paradigms) won't prove anything about the sound quality (other than that I want my own front speakers back). I'm sticking to a separate processor.
Old 11-02-2009, 11:00 PM   #20
Marky P
Posts: n/a
Place holder for part 2
Well?
Old 12-02-2009, 1:27 AM   #21
Originally Posted by Marky P View Post
Well?
Im very time committed, and the tests eat into what spare time I have. Writing a report takes a while too
Part 2 will be up today (Thursday).
PaulWilliam (12-02-2009)
Old 12-02-2009, 5:26 PM   #22
killer10971's Avatar
Thanks: Gave 223, Got 21
what are the reported issues ??
Old 12-02-2009, 5:52 PM   #23
Slackadder's Avatar
Thanks: Gave 36, Got 82
Killer,
I believe the major issue is "pops and clicks" when changing source - but as I am not an owner probably best for them to summarise the "bugs".
Would love to get one but probably best to upgrade the panel first......
Anthony
killer10971 (13-02-2009)
Old 12-02-2009, 6:50 PM   #24
eiskurve's Avatar
Thanks: Gave 2, Got 10
Issues with mine are:
Occasional pops or clicks when changing source
Guaranteed pops and clicks when using Sky HD box, (program to menu or fast forward back to normal speed)
Long delay in audio restoration after fast fwding with Sky, (doesnt seem to suffer as bad with DVD or BD). But the audio problems were not apparent with my 300, so they are 600 related.
My unit doesnt respond to handset to revive from standby after a few hours or an overnight. Annoying when you fire up sky from handset and you have to re-use main power switch to fire up avr 600
Current doesn't retain custom setting of modes in setup menu after power off-on.
These are small issues and I know Arcam are working on them already. But it should be said that these apart the unit is SUPERB. A massive jump in audio quality and power over my 300 and with a great video section as well. The upscaling is ace, (better than my source dv 137) and overall I am blown away by it.
This is without mentioning the source direct capability, where the soundstage and power are ace. It has effortless oomph but is oh so subtle.
Old 12-02-2009, 7:12 PM   #25
Originally Posted by Slackadder View Post
Killer,
Anthony
These are the same issues that the AVP700 had, pops and clicks when changing sources.
Old 12-02-2009, 9:40 PM   #26
Quintus's Avatar
Thanks: Gave 30, Got 22
I posted this earlier this morning in the other AVR600 thread as I did not realize that a new thread had been started. I think this post belongs here.
(Please note that I recently changed by Username to "Quintus" from "The Arcman"! Thanks Ian!)
I know I told you all that I would be receiving my AVR600 on Friday but.....wait for it....the dealer advised that the unit arrived early! I picked it up yesterday and spent the evening setting it up. I can't post a full review yet but the sound out of this system is UNBELIEVABLE.
Even my wife, whose not much of an audiophile (and who almost divorced me when she found out how much the "upgraded" system was costing...but that is for another day!) heard sounds that neither of us had ever heard before when listening to some of our favourite music via the Apple TV (in apple lossless of course!). We could actually hear the guitarist's pick against the guitar string and Tori Amos' lips separating between verses! Like I said, UNBELIEVABLE!
Watched the first scene of The Gladiator in DTS. WOW! Anyone notice the sound of children playing in the background in the very first seen before the "Germania" scene appears. We did...for the first time! Watched the initial bank robbery in The Dark Knight in TrueHD. Double WOW!
OK, here is some meat for those of you looking for answers:
(1) I did not experience any problems with audio delay via HDMI or Digital when pausing and playing itunes on Apple TV or on the Sony PS3 or on my Scientific Atlantic PVR.
(2) I did not notice any crackles when switching between inputs.
(3) The only odd sound I heard was when "muting" and "unmuting" the AVR600. Sounds exactly as though you are turning the entire system off and back on whenever you mute and unmute. This may be normal behaviour given the amount of watts that is going through the amp? Maybe?
(4) One thing I did notice, however, is that the system allows you to turn off certain modes so that you don't need to toggle through them all (i.e. Dolby Logic, DTS Neo6 etc...). Works fine after you make the changes but the changes are not saved when the system is turned off and back on again. Anyone else notice this? Extremely minor but a bug in the software nonetheless.
I obviously haven't tested the whole system yet as I've just only recently set it up and will attempt to post a full review in due course.
Thanks to all who encouraged me to proceed. I am incredibly impressed!
Old 12-02-2009, 9:40 PM   #27
Quintus's Avatar
This one is also a cut and paste from the other thread also. Frankly, I think the other thread should be closed.
Originally Posted by RobertPaulson
You should report it to Arcam (referring to item no. 4 above), I'm sure they'll appreciate hearing about the problem and also more than happy to sort it out.
Just a thought: Do you have to save the setting some way to make them permanent?
I reported it today and heard back within 2 hours! Arcam has recreated the problem at their end and intend to address it in a software patch. As I said, this is a pretty inconsequential issue but good to know that their customer service is AAA+.
Old 12-02-2009, 9:57 PM   #28
MOD Comment: Merged two threads and moved review part II to top of thread. Kept this post as contains thanks to poster.
birdseed (13-02-2009), cdnxpat (13-02-2009), ianmacd (13-02-2009), Ian_S (13-02-2009), Mr X (12-02-2009), PaulWilliam (13-02-2009), Perceval (12-02-2009), RonCH (13-02-2009), Starred (12-02-2009), TheBlueFalcon (12-02-2009), Thomefan (12-02-2009)
Old 12-02-2009, 10:22 PM   #29
Thanks: Gave 35, Got 3
I have my name on one of the 100 AVR600's due to be shipped at the end of Feb. I simply can not wait to get it now.
Thanks to everyone for the feedback. And I agree, Arcam's customer support has been excellent.
Old 12-02-2009, 10:25 PM   #30
Mr X's Avatar
Thanks: Gave 488, Got 288
First and foremost thanks Coldmachine
OK getting seriously tempted. I am no expert so welcome advice....
I am currently running an AVR350 and B&W XT series. I'm not really able to add any more rears so can't benefit from 7.1 nor can I change my speakers at present. My point is can anyone second guess whether I will notice such a dramatic experience given my speaker set up and limitations. I'm guessing that my speakers are good but nowhere near what's needed to get the best from the 600?
Any advice gladly received
Thread Closed
