Dv137 & Avr 350(new) Or Dv137 & Avp700 With P1000 (used)
Old 26-10-2006, 4:10 PM   #1
clarkesville's Avatar
3,159, Level: 13
Points: 3,159, Level: 13 Points: 3,159, Level: 13 Points: 3,159, Level: 13
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 25, Got 0
I will be looking to purchase a DV137 & AVR350 shortley but i`ve been offered a 3 month old dv137 with a AVP700 with a P1000,having tested the 137 & 350 and been blown away with the performance shill I buy new or should I go for the second option
Regards
Clarkesville
Old 27-10-2006, 7:31 AM   #2
2,093, Level: 10
Points: 2,093, Level: 10 Points: 2,093, Level: 10 Points: 2,093, Level: 10
Re: Dv137 & Avr 350(new) Or Dv137 & Avp700 With P1000 (used)
I had a similar option but all new and I went for the second 700/1000 option, much better.
clarkesville (27-10-2006)
Old 27-10-2006, 10:07 AM   #3
gpa gpa is online now
gpa's Avatar
8,407, Level: 21
Points: 8,407, Level: 21 Points: 8,407, Level: 21 Points: 8,407, Level: 21
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 543, Got 324
Regards
Clarkesville
Second option, you will not be disapointed
Old 27-10-2006, 3:44 PM   #4
4,988, Level: 16
Points: 4,988, Level: 16 Points: 4,988, Level: 16 Points: 4,988, Level: 16
Thanks: Gave 16, Got 16
2nd m8
Old 27-10-2006, 7:19 PM   #5
2,490, Level: 11
Points: 2,490, Level: 11 Points: 2,490, Level: 11 Points: 2,490, Level: 11
Thanks: Gave 1, Got 4
Do you really need that power? No, buy the AVR350.
clarkesville (30-10-2006)
