Originally Posted by Avi Which part of the HDMI specification covers passthrough not related to 3D ?
Does that mean the 23.976hz passthrough can be dynamically switched to either HDMI output without having to swap the TV or PJ cable around or use an external switch ? |
No, that's not what I meant - What I was trying to say was that people associate 1.4 HDMI with 3d and not with the actual difference being ARC / Ethernet.
As far as I know if you want to dynamically switch it, you have to split output 1 - so still not a big deal unless you switch them on both at the same time. It's still a non issue and again not something may would run into. I'll wager most people would just have their telly in output 2 because they simply can't see the difference.
Originally Posted by Avi The point isn't about HDMI version it's about how the manufacturer implements the video solution. I've used 23.976Hz out for years with both DVI and numerous revisions of HDMI.
There's lots of excuses but the simple fact is Arcam appear to have designed or "bought it" a design that doesn't allow 23.967hz Blu-ray film (which is the vast majority of Blu-ray film) to be output at the correct frequency irrespective of if this is "passthrough" the video section or processed in some way. |
It's the same on many amps, it's lazy technology across many manufacturers, there's not enuff demand or outcry about it for it to be corrected.
Originally Posted by Avi FOC means free of charge for those that purchased the product and found it couldn't support Blu-ray film output at the correct native frequency i.e. fix a video design issue not be charged to upgrade for other features. |
Of course not, does anyone? It wasn't a big enuff deal, that's why hiding it under the guise of 3d makes it seem acceptable.
Originally Posted by Avi The original point was simply that any company that understands video and is serious about video quality wouldn't force incorrect frame rate conversion especially for a format such as Blu-ray what is largely about image quality. It suggest Arcam's "in house" video expertise isn't particularly good or video isn't a performance priority. Either way this is a concern with regard to claims about "in house" Blu-ray player design given their recent video design decisions.
Avi |
I agree but that's not the way the world works, they don't cater to those 2% with a keener eye. It's not like Arcam or any other company didn't know or didn't take it into consideration. I have to have faith that anyone with that level of skill in programming and design cannot possibly be that thick - or I may as well just take myself out back with the shotgun.
A lot of people would kick off about the lacking volume knob and say it's a bad design.. which it is for some, for knob enthusiasts I guess.
It was a way to cut costs, nothing more.
Now the blue ray player... after reading that thread you have to wonder if the cleaning lady is writing the code for that.
