Arcam rDAC Review
Old 22-06-2012, 10:16 AM   #301
Thanks: Gave 51, Got 43
Thanks for the reassuring replies guys.
Could i ask what interconnects you guys are using? I'm wondering if its possible that my cheap 19.99 one is the weak link?
Thanks.
Old 24-06-2012, 5:11 PM   #302
Thanks: Gave 3, Got 32
I am using a pair of XLO Pro RCA interconnects. They are about 16 years old.
Old 29-06-2012, 9:37 PM   #303
Thanks: Gave 3, Got 20
People have played with the PSUs but does anyone have any feedback of mods to the DAC itself such as by Fidelity Audio?
It's difficult trying to quantify the quality and cost implication of any potential mod versus using the same money just to buy a higher end DAC...
Any ideas or opinions?
Old 14-07-2012, 4:30 PM   #304
Talking
Thanks.
The interconnect used between pc and dac is an Audioquest Cinnamon (usb2.0)
Interconnects on my stereo are all vandenHull;
The second (carbon) between pre and (2stereo) power amps
The first, "the ultimate" (carbon) between dac and pre-amp
The first, (carbon) between minidisc and pre-amp
QED silver biwire from poweramps to loudspeakers
I was told that there is a "rule" or something that says you should spend inbetween 10 - 15% in total equipmentvalue on interconnects, if this is true i don't know.
My system is getting there finally, i was having alot of trouble with my pc hardwired to the Nas through our router even though i was using cat7 cables.
Alot of noises and clicks sounding like the drummer was skipping a beat, very frustrating
Asio wasn't helping much, i thought
Finally last week i pulled the networkcable from the pc and switched to wifi (router to pc) and i'm still waiting for the clicks
Finally it works like it should be, Albumplayer is working fine for me so after my vacation i'm gonna setup the database with correct albumcovers and info on every artist in my system.
The Rdac is sounding better and better every day so i'm very happy after saying goodbye to my old Arcam Alpha9.
Keep you posted after the 100 hours
Old 28-08-2012, 8:15 PM   #305
rdac and airport express, still usb connect?
Originally Posted by sounddog View Post
I'm not 100% sure, but I thought the MacBook Pro and MacMini only did upto 96k via optical dispite that spec quoted.
Also the USB interface of the rDAC is async USB (from dCS) so should have lower jitter and therefore improved sound quality.
And, regardless of the capabilites of the MacMini / MacBook Pro optical output's spec: the rDAC can only do upto 48k via optical.
As an aside, the Apple TV and AirPort Express are both only capable of 44.1 & 48k.
In summary, with the rDAC, the answer is pretty clear: if you use a computer as the source, use the USB connection.
Eloise
_____________________________
if i connect my rdac to an airport express, will the usb on the express output sound? i know the apple tv will not.
can i play FLAC files through the express (i believe ATV does not allow this)?
if the express outputs through USB, is this better option that optical connection via ATV?
and finally, would i be better off connecting rDac directly to computer, from a sound quality perspective?
thank you
Old 28-08-2012, 11:07 PM   #306
xxFLUIDxx's Avatar
Thanks: Gave 27, Got 49
thank you
No
No
See 1
Yes
Short and sweet but hope it helps
Old 29-08-2012, 6:43 AM   #307
Thanks Fluid, it does help.
Will the computer via direct USB produce a significant improvement? Is the lower sound quality using the ATV or airport express because of the apple unit itself or because I would have to use the optical input in this scenario instead of the USB?
If so I was thinking of going the USB route when I want to have a good session myself, and then getting ATV so my wife can use her Ipad without having to turn on the computer and connect it to the rDac. Do you believe there would be a difference in sound between ATV and express?
And finally, is there another option to stream music wirelessly into the DAC that would yield better result than the apple product, without spending too much? I am getting a synology NAS, not sure if that has airplay.
Thanks for your help.
Old 07-02-2013, 6:40 PM   #308
Thanks: Gave 26, Got 17
Hi all, I have just procured an rDAC-kw from these forums and now I am interested in upgrading the power supply.
The Maplin VN10L Regulated AC Adaptor seems to have had good results for some people, but these seem to have been discontinued. Is anyone aware of an equivalent product at reasonable money (circa twenty quid) that would do the job?
If not, I would be interested in buying the VN10L from anyone who has upgraded beyond their rDAC.
Thanks!
Old 08-02-2013, 8:48 AM   #309
Thanks: Gave 48, Got 349
No still available and on special offer
Low Power Multi-Voltage Desktop Power Supply : Multi Voltage Power Supplies : Maplin Electronics
FrancescoNoir (08-02-2013)
Old 16-03-2013, 3:28 AM   #310
Timmy C's Avatar
Thanks: Gave 79, Got 133
Originally Posted by larkone View Post
That link doesn't take you to a Maplin VN10L. Is this one a worthwhile upgrade as well or can anyone suggest another alternative as good as the VN10L?
Old 16-03-2013, 6:22 AM   #311
Timmy C's Avatar
Scrap the above question....thought mine was faulty but it's working fine now it seems. I have another question though. I'm using my rDAC with a Squeezebox so was wondering if there would be anything to be gained in upgrading the power supply on the Squeezebox as well or is that not gonna help.
