Go Back   AVForums.com > Manufacturer-Specific Owners' Forums > Arcam Owners' Forum
Latest AVForums Movie Reviews
My Bloody Valentine - Special Edition Blu-ray ReviewThe Universe: Complete Season One Blu-ray ReviewTerminator Salvation Blu-ray Review20th Century Boys: Chapter 2 - The Last Hope Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray Review
Scrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Lg 32pg6000 - sky remote code GeeMan72 Plasma Televisions 1 03-03-2009 11:02 PM
SD Card Problem - Capacity overload CJdamaster Hard Drives and Memory - RAM/Cards and Sticks 11 20-01-2009 4:13 PM
Which Digi Box Should I Buy Now After Same Old Problem Jay Adam Freeview 5 11-01-2009 3:41 PM
got robbed, need an A-Z by title list Fordy Movies and TV Programmes On Disc and Downloaded 11 09-01-2009 11:11 PM
PS3 5.1 surround sound problem paulflee PS3 33 09-01-2009 8:26 PM
Old 09-01-2009, 12:18 AM   #1 (permalink)
Thanks: Gave 28, Got 45
AVR280 Remote problem
Problem with CR100 remote on AVR280 perhaps coincidentally following attempts to set it up to control other devices.
The volume and mute buttons work.
Input selector buttons and display button don't work (probably others but I haven't tried).
Mode button switches input to SAT
Amp button doesn't seem to do anything.
Cursor keys don't work properly in menu - to move cursor up down uses left right keys and vice versa. OK doesn't work. Can't select main setup items.
I've followed the manual instructions on resetting the remote lots of times also tried removing batteries.
Any ideas to fix, or is the remote broken?
doug56hl is offline   Reply With Quote
Old 09-01-2009, 12:34 AM   #2 (permalink)
Druboo's Avatar
Thanks: Gave 66, Got 97
Re: AVR280 Remote problem
This thread may help
Haven't checked if Crustys links are still working.
Andy
Panasonic 50HD8, iScan VP50, HDFury, Sky HD, Arcam FMJ AV9, DV139, Parasound 2205a, Transporter, Squeezebox 3, X-DAC V3(Modded), Db Linear PSU, PMC TB2+ TB2M-C, SVS PC13 Ultra, SMS-1, Pronto Pro, Xbox 360 Elite, 360 HD Drive
Druboo is offline   Reply With Quote
Old 09-01-2009, 12:49 AM   #3 (permalink)
Doesn't work in this case.
Update, all buttons produce nothing on the display (apart from as noted in my first post) except CH right key which now functions as the MODE button.
Old 09-01-2009, 8:50 AM   #4 (permalink)
Glad I am not the only one to have this problem. I first thought it was result of trying to program it so I have stopped trying to do that, but currently on my 5th remote in 18 months.
Thankfully my local dealer is very helpful, and after the first 2 were sent back to Arcam which confirmed they were faulty they now just swap my remote with their demo units to stop me waiting for Arcam to return a new one.
The last time it happened it was when the batteries ran out, but has also been mid movie. I pressed play and all ok, 90 minutes later and try stop and its doing the behaviour described above. I cant believe I am that unlucky to have so many broken ones so I think there is a real probelm with the CR100.
flysi is offline   Reply With Quote
Old 09-01-2009, 1:40 PM   #5 (permalink)
I was hoping for a quick fix from those in the know but it seems likely it is a duff remote. I've contacted Arcam support.
I'm going to be a bit annoyed if this becomes a saga like yours flysi of returning remotes time after time, especially as I bought mail order and the postage costs will start to mount up.
Old 16-04-2009, 11:40 AM   #6 (permalink)
I've started to suffer the exact same problem as described by the poster with my cr100. It works all other components fine apart from the amp itself.
I spoke to Arcam support this morning and they are sending me a new remote.
Would be interested to hear if anyone else has had this issue and specifically if the original poster's issue was resolved.
Sinkemlow is offline   Reply With Quote
avr280, problem, remote
