Originally Posted by Timbo21
So are you saying you watched Blu-ray on the PS3, and then watched the DV79, and it was terrible?
Did you try normal DVD with the PS3, because that will give you an indication if there is something wrong with your DV79, since the DV79 should be much better than the PS3 for straight DVD.
The other thing is that your pj may be particularly poor at scaling SD. Some of the artefacts you talk of could be caused by poor scaling, whic can cause 'ringing'. However, many find it hard to go back to SD after HD.
T.
I think what I am saying, is that when to comparing blueray to dvd it made me spot these artefacts that I didnt think i should have with a decent Arcam dvd player. I was expecting lower res, and softer (which it was) but didnt expect this ringing effect.
I didnt try the dvd in the ps3 as it was a region 3 disk which it wouldnt play (we were comparing Casino Royale on both formats). The ps3 has gone so cant try your suggestion.
Ive not seen the ringing with other SD sources such as the Wii or Xbox so dont think its the projector. If i get a chance, I'll try another DVD player (albeit not HDMI) to see what the results are like.
