Formatting HDD
Old 16-07-2012, 4:26 PM   #1
Thanks: Gave 3, Got 8
Formatting HDD
Quick one.. If I format a windows HDD using a caddy using Mac disk utility will I be able to put it back in the laptop and install windows? Can't do it on the laptop as I can't get past the blue screen. Checked online and the only option is to format.
Old 16-07-2012, 10:14 PM   #2
Thanks: Gave 21, Got 621
You need an NTFS driver in order to format a drive for use in Windows. Paragon should do the trick.
Old 17-07-2012, 6:33 PM   #3
Eminent Member
dejongj's Avatar
Thanks: Gave 2,080, Got 2,740
Not certain whether you can boot from an ExFat drive but you could format it like that.
Alternatively you could format as fat32.
Then once windows is installed you can always convert to ntfs afterwards.
Old 17-07-2012, 6:48 PM   #4
Not sure what I can do now as he's bought it from some dodgy shop and I need to install XP back onto the formatted HDD but it has a bios password which he doesn't know... I've been on google to see if I can install xp onto an external HDD with a Mac but I can't see any way that doesn't look way too complicated. Anyone know how? He bought the laptop second hand from a local shop who don't know the bios password either!
Old 17-07-2012, 7:18 PM   #5
Eminent Member
Thanks: Gave 131, Got 3,803
This may be of assistance:
How to clear an unknown BIOS or CMOS password.
