Originally Posted by RobertStockholm It's 1280x720, 30fps so in Streamclip I used Export to Quicktime, compression "Apple XDCAM EX 720p30 35Mb/s VBR", Quality 100%, Frame Size 1280x720 unscaled.
1. One strange thing is that the result size was 1248x702. Why?
2. If I import several video clips at once into Streamclip, it automatically puts them together - can it export them individually?
I imported to FCPX and exported to H.264 and the difference from the original file from the camera was minimal (but detectable on the red frame around the photo)
3. Why should I at all use streamclip before importing into FCPX? Maybe because otherwise FCPX changes the files to ProRes so they will be huge to work with before I export to H.264 anyway? |
Hi Robert,
1) I dont know why it would go 1248X702, perhaps its something to do with the sensor size on your LX2, did you choose 'unscaled' in the streamclip settings? Also you might need to deinterlace.
2)You can export the streamclips separately, you need to explore the batch list settings to choose the from and to destination folders to do them individually if you choose it that way.
3)As you said, if you dont use streamclip in FCPX you will be working with huge files at the expense of your hard drive, remember they are at least 2.5 times larger than the originals which are already large. Apple XDcam is about 90% the size of the original and no real image loss.
To put it in a nutshell this is my usual work flow:
1)Put my original H.264 files somewhere on a hard drive, then i back them up to another hard drive.
2)In stream clip I convert only those files i wish to use after previewing and logging them all, I put them in a separate folder in the same location as the original files, labelled XD25 or whatever. So now the hard drive reads:
summer hols '11 : open this and you have:
H264 : these are your originals
XD25: these are your streamclip converted files.
If you are cocky enough to realise that you have converted into something you know is what you want, say for an internet ad or youtube thing, you can BIN the original files and just keep the streamclip conversions, saving space in hard drive! Hope this helps, but i am not an expert at all.
3)From this folder i import only those i wish to work with in FCPX.
I cant explain the cropping difference in the two images you posted (?) Am interested though if someone does know.
