Originally Posted by Flashy No particular reason for the router, really, other than habit, but I'd want to power down if away for a weekend or on holiday. I'm not too keen on leaving the Airport Express on when not in use, though, partly because it gets so hot and partly because another LED shining in the living room constantly would irritate me. And nobody suggest a tiny bit of gaffer tape as a solution.  |
Personally, I think turning it off for a weekend away is a bit OTT, a 2 week holiday away fair enough, but not a weekend.
Originally Posted by Flashy I'm not sure speed's the problem, as the router takes mere seconds to get it's initial connection – iPhone connects quickly, PCs switched on at the same time as the router have their connections as soon as they're booted up, so take longer to start than the router does. |
Here's what we need to understand-when you say these machines are getting their "connections", what do you mean, "connections" to what?
Originally Posted by Flashy If I've told it to use "same IP" for everything (and the router did remember that after being turned off), what harm does turning off the router actually do? |
What do you mean by "same IP for everything"?
You set the reserved IP by
device-so laptop, iphone, Airport Express etc.
Originally Posted by Flashy Its settings seem to be preserved day-to-day. Seems the only problem is the Airport being picky about when its going to connect. I'm not unwilling to try anything, just seems this little white box is necessitating quite a lot of change to other things.  |
I thought you knew AE's weren't that simple to get going?
So, if everything else is coneecting to the router and the internet without any issues, then the problem lies (in theory!) with the Express's config.
Originally Posted by Flashy Only other question about the router is whether deleting items from its devices list would cause any problems? |
No problems, as long as you delete the right ones!
Originally Posted by Flashy My laptop is listed three times in the WLAN section (as opposed to the ethernet one), for some reason. Can I delete all three and start again? |
Yes, turn the laptop off (or at least turn it's wifi off), delete the 3 entries from the router, put the laptop back on your wifi and check it's IP. Then go into the router, check it matches and reserve it.
Originally Posted by Flashy That would at least cut down on the number of IPs the router thinks need to be assigned, wouldn't it? |
The router can handle something like 254 addresses, but a little housekeeping of the devices won't hurt.
Originally Posted by Flashy Can do a screen cap this afternoon if that would help. |
Nothing to lose.
Originally Posted by Flashy I still don't understand why the AE has two WLAN entries, if I'm honest. I'll do a shot of that, too, to illustrate what I mean. Just trying to flag up anything that could be a potential conflict. Like you say, process of elimination. |
Absolutely.
I'll check my router and see what mine shows and I'll stick a screenshot up).
