Originally Posted by Thomss Hi,
what you will need to do it is have the first audio track set to:
AAC > Dolby Pro Logic 2 > Auto > 160 kbps
then in the 2nd audio track under "Audio Codec" select the AC3 and that's it.
Are you using version 0.93? there is a good AppleTV preset in there which very well. I use a slightly different config with 59% Constant Quality and it looks great, with pretty good files sizes. I only wish I hadn’t done 400 of my DVD's with Avg Bitrate of 2500 when I first got in to this lol, I'm half way thru re-doing them all now with 59%
have fun  |
Right now I am copying Sideways
audio choices are
Track 1
SOURCE - English (AC3) (5.1 CH)
AUDIO CODEC - AAC (FAAC) or (AC3 Passthru)
MIXDOWN - As discussed in first post
SAMPLERATE - Set at Auto
BITRATE - Set at 128
what is the best setting and do I have to enter something for track 2?, is that correct?
In Video what is the best bitrate to set?
