Anyone having problems with Adium + MSN?
Old 12-01-2009, 3:32 PM   #1
14,246, Level: 28
Points: 14,246, Level: 28 Points: 14,246, Level: 28 Points: 14,246, Level: 28
Thanks: Gave 167, Got 196
I'm just trying to load up Adium and it's failing to connect to MSN at the mo? I'm getting 'Unable to retrieve MSN Address Book' in the connection status. Anyone else having any problems?
Old 12-01-2009, 4:27 PM   #2
4,482, Level: 15
Points: 4,482, Level: 15 Points: 4,482, Level: 15 Points: 4,482, Level: 15
Thanks: Gave 16, Got 97
Re: Anyone having problems with Adium + MSN?
EXACTLY the same issue for me too.
Adium + Googletalk works fine though.. .. .. ..
Old 12-01-2009, 9:15 PM   #3
4,018, Level: 14
Points: 4,018, Level: 14 Points: 4,018, Level: 14 Points: 4,018, Level: 14
Thanks: Gave 99, Got 103
It's a problem with MSN and a library Adium (amongst other apps) uses. News here.
captainff (13-01-2009)
Old 13-01-2009, 12:06 AM   #4
4,482, Level: 15
Thanks for the info .. .. .. .. everything seems to be back to working order again now.
