Resize Partition Help
Old 27-11-2008, 8:07 PM   #1
Monopot's Avatar
8,369, Level: 21
Points: 8,369, Level: 21 Points: 8,369, Level: 21 Points: 8,369, Level: 21
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 354, Got 169
Just need some help with resizing a partition.
I had a 750GB USB external drive which I had 400gb for time machine and the rest for storage of media files. I've recently brought a time capsule so have the storage area backed up on this now, so no longer need the 400gb for time machine.
I want to extend the storage area to fill the drive so I removed the 400gb partition but I can't now extend the other one.
See the attached screenshot, I need to extend the IcyBox partition so how would I do this? I've tried typing in the new size but no joy.
Old 27-11-2008, 9:14 PM   #2
5,649, Level: 17
Points: 5,649, Level: 17 Points: 5,649, Level: 17 Points: 5,649, Level: 17
Thanks: Gave 44, Got 72
Re: Resize Partition Help
Unfortunately, due to the way live partitioning has been implemented you can't move the used partition into the free space.
What you can do though (I think ) is create a new partition in the empty space, copy your data to it, then delete the old partition and then expand the new one into the empty space by using the resize-handle in the bottom right hand corner. It'll take a some time though.
Good luck .
Monopot (28-11-2008)
Old 28-11-2008, 11:12 AM   #3
Monopot's Avatar
8,369, Level: 21
Activity: 3.4%
Good luck .
Sounds like a plan, good man! Never thought of it that way.
Old 28-11-2008, 1:04 PM   #4
5,649, Level: 17
I've never tried it that way… so I'd be interested to here the outcome.
Monopot (02-12-2008)
Old 02-12-2008, 8:10 PM   #5
Monopot's Avatar
8,369, Level: 21
Activity: 3.4%
Just wanted to say yep it worked.
Copied all my data from the 2nd partition to a new 1st partition. Wiped the 2nd and then expanded the 1st. All worked fine.
You the man
Old 03-12-2008, 2:36 PM   #6
5,649, Level: 17
That's good to hear.
Old 03-12-2008, 9:07 PM   #7
4,018, Level: 14
Points: 4,018, Level: 14 Points: 4,018, Level: 14 Points: 4,018, Level: 14
Thanks: Gave 99, Got 103
Glad you got this sorted. There is another option you might be able to use in future. GParted is excellent for this sort of job. It's a Linux live CD, so you boot from it and can then move, copy, grow, shrink and change partitions. It can't do all of those for HFS+ formatted partitions, but handles FAT32 and NTFS fully.
Old 04-12-2008, 7:50 AM   #8
Monopot's Avatar
8,369, Level: 21
Activity: 3.4%
Thanks yeah, I've used that in the past at work for NTFS drives. Good little program!
