AC Powered USB Hub
Old 30-07-2012, 1:40 PM   #1
Sebastalona's Avatar
Thanks: Gave 1,792, Got 1,262
AC Powered USB Hub
Can anyone recommend a mains powered USB hub? I've ran out of ports on my iMac.
Old 30-07-2012, 3:38 PM   #2
Limited Member
Thanks: Gave 54, Got 1,083
I've always used the Belkin 7 port ones.
Old 30-07-2012, 3:49 PM   #3
Thanks for that. Do you have a link?
I have 4 ports currently used up by WD 1TB Drive (x1), WD 2TB Drive (x1) and a Samsung Blu Ray Writer (x2).
I bought a normal BUS powered one thinking that would suffice as the WD drives are externally powered. However, my mac still does not recognise the drives or blu ray drive.
So I'm assuming I need an AC powered USB hub?
Old 30-07-2012, 4:08 PM   #4
This looks like it will do the job:
D-Link USB 2.0 7 Port Hub | Ebuyer.com
Old 30-07-2012, 4:09 PM   #5
Limited Member
I've always used powered as something or other is likely to need it and I usually cascade two Belkin 7 ports into one another. This is the current one (I use an older model) which ships with an AC adaptor from the spec Belkin : 7 Port USB Plus Hub
Sebastalona (30-07-2012)
Old 30-07-2012, 4:11 PM   #6
Limited Member
The D Link looks fine if you prefer it.
Old 30-07-2012, 7:26 PM   #7
Thanks: Gave 21, Got 621
You do realise that the point of USB is to be hot swappable right? ;-)
Old 30-07-2012, 7:27 PM   #8
You lost me at 'You' mate!
EDIT: I assume you mean why not just swap the USB devices as and when need? I could, but it's not the most practical for me. My kids (7 & 5) are always wanting to plug in their ipods to put on new music. It's only a matter of time before something gets damaged! Easily accessible USB ports are a must!
Old 30-07-2012, 8:33 PM   #9
Senior Moderator
Steven's Avatar
Thanks: Gave 2,339, Got 5,123
Over something like five and a half years later mine is still working. Exactly this model!: Belkin F5U237QEA Hi-Speed USB 2.0 7-port Hub: Belkin: Amazon.co.uk: Computers & Accessories
Old 30-07-2012, 8:40 PM   #10
Was meant tongue in cheek fella, as was just thinking back to when USB was released and the whole selling point was being hot swappable like nothing that went before. Just amuses me that it's never really worked in that way. I do agree that multiple ports are a must though, don't worry.
Old 31-07-2012, 12:08 AM   #11
Limited Member
Yep they are long lived. The lifetime warranty also helps
