Originally Posted by valleyboy22 Hi all,
My dvd player comes up "protect" when you put it on and turns straight off??Know people have had problems with this,but have anyone narrowed this problem down so i know what to do??Its only 7months old and gutted this has happend so soon.
V Boy  |
Hi V Boy,
Yes this is a `known` problem - it is listed in the technical support pages - faq`s on the Samsung website. They advise you there to contact Samsung technical support phone number as the system may need to be repaired.
I have had this problem with 2 different Samsung home cinema sytems. You may be told it has something to do with the fan / speaker cables or ventilation but in both my cases it was none of these.
All I can do is advise you to go through this process, but do not accept that there may be no fault found if it has to be taken in for repair. In my situation I ended up contacting Samsung H.O. and dealing with a senior manager their after being given the run around by the customer support staff. They are better now though - thank God.
Good Luck.
