help for a thicko?
Old 24-03-2009, 7:36 PM   #1
1,826, Level: 9
Points: 1,826, Level: 9 Points: 1,826, Level: 9 Points: 1,826, Level: 9
help for a thicko?
The more i read around about surround sound systems, the more confused i get so, i thought i would try a nice simple question. Assuming i have £300 to spend and am looking to link up a tv, xbox and ps3, what should i be looking for?
Old 24-03-2009, 7:55 PM   #2
tom 2000's Avatar
6,781, Level: 19
Points: 6,781, Level: 19 Points: 6,781, Level: 19 Points: 6,781, Level: 19
Activity: 5.7%
Activity: 5.7% Activity: 5.7% Activity: 5.7%
Thanks: Gave 90, Got 129
Re: help for a thicko?
Connectivity.
Some all in ones are extremely limited in their ability to cope with external components. Your PS3 connects to sound system by HDMI. As far as I know the XBox connects to your sound system via HDMI also. I assume your tv has more than one HDMI input should you decide to add Sky HD which also connect to sound system via optical audio speakers.
A Sony amp with separate speakers will stretch your budget but is flexible.
You dont need a traditional all in one as you have all players required.
Old 24-03-2009, 8:05 PM   #3
1,826, Level: 9
thanks for the reply Tom
You are correct, the ps3 and xbox are both connected to the tv by hdmi.
I had assumed an all in one system would have been the way to go as i thought they would be easier to set up than seperates. Apart from that, i guessed i would be needing some sort of optical input to the amp from both the ps3 and xbox. Do some amps have more than one optical input, or is a switch the way to go?
Old 24-03-2009, 10:21 PM   #4
tom 2000's Avatar
6,781, Level: 19
Activity: 5.7%
You dont need optical from PS3 and I guess not from XBox but I cant speak for that. Some have two inputs but I think Sky is is the main requirement for one. Most other devices transmit full sound by HDMI.
Old 25-03-2009, 1:29 PM   #5
9,193, Level: 22
Points: 9,193, Level: 22 Points: 9,193, Level: 22 Points: 9,193, Level: 22
Thanks: Gave 470, Got 535
For all in ones, look at amp & speakers systems - ie no dvd player.
For ps3, to get hd audio from blu rays, look at systems which accept decoded uncompressed audio (linear pcm) over hdmi.
You don't need a system which decodes hd audio with ps3, as it decodes it internally and outputs uncompressed over hdmi.
Amp & speakers systems generally have good connectivity too - a few hdmi inputs, a couple optical, digital coax, a few rca phono.
To meet the above criteria, look at systems such as av63+, htddwg800, htss1300, htsf1300.
Powered by
 Latest popular product prices
Panasonic SC-XH50
5 prices from
 £99.99 Click to show/hide the offers
Sony DAV-TZ135
6 prices from
Samsung HT-D350
5 prices from
 £129.00 Click to show/hide the offers
Samsung HT-D450
4 prices from
 £139.96 Click to show/hide the offers
Samsung HT-D5000
7 prices from
 £143.98 Click to show/hide the offers
Logic3 Soundstage 5.1
2 prices from
 £166.59 Click to show/hide the offers
LG BDH9000
2 prices from
 £169.30 Click to show/hide the offers
Panasonic SC-HTB10
4 prices from
 £186.07 Click to show/hide the offers
 Updated February 12th at 9:30am. Prices include delivery.
[IMG] code is Off
