| Re: What do you think of this Sony Setup?
The HT-DDWG800 will provide better sound quality (though that's subjective, I guess), and you can upgrade the speakers later if need be. It also provides much better connectivity, if that would be an issue for you.
On the downside, it's bigger and therefore (as you say) not as partner-friendly, and unfortunately it doesn't come with speaker stands of any sort.
The HT-SF2300 is basically identical to the HT-SF1300, the only differences are cosmetic, and imho not worth the extra dosh - it just blends in better with the two Blu-Ray players I guess.
I think the main differences between the S350 and the S550 are that the S550 adds the following: DTS-HD Master Audio, DTS-HD High Resolution Audio decoding support, and analog 7.1 output support. The S350 will only decode those two DTS inputs as DTS core (but is it that much of an issue?).
If you get an A/V amp which supports LPCM input over HDMI, then you probably won't need the analog outputs anyway, so the only tangible difference is the DTS-HD MA and HRA support.
Also, whoops - I actually linked to the 32" version, though that might be too small for you..?
