| Re: Panasonic SH-FX67 wireless kit - thoughts?
Bought and installed the very Panasonic kit about 2 weeks ago.
So far does work well, the only criticism so far and this all depends on your room set up and how far you have the rear speakers away from you.
They do emit a small hiss, particularly noticeable if the volume is down or quiet bit of a film etc. When the volume is up and there is noise coming out then they sound perfect.
The wireless works well, but each speaker does need to be connected to the wireless unit - we have no issues with that as it sits beneath the sofa.
Hope this helps.
