Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
Today's price checkPowered by
Sony DAV-DZ280
Panasonic SC-BT200
Sony HT-IS100
Panasonic SC-BT205
Sony DAV-DZ280
Panasonic SC-BT200
Sony HT-IS100
Panasonic SC-BT205
LG HT304SU
Samsung HT-Z220
Panasonic SC-PT470
Samsung HT-BD1220
Samsung HT-X720
Panasonic SC-PT170
 More...Prices updated November 25th at 8:30am and include delivery.
Sony HTSF-1300 - (help! non bravia / PS3 owner) mgoodall7 All-in-one Systems 3 31-10-2008 1:37 PM
sony htsf-1300 auto calibration jestix All-in-one Systems 2 26-10-2008 4:59 PM
Sony HTSF - 1300 Connection HELP... jamesfisher1081 All-in-one Systems 2 23-10-2008 8:30 PM
Difference between HTSS 1300 & HTSF 1300 speakers netowt All-in-one Systems 0 16-07-2008 2:37 PM
htsf 1000 speaker system tonyk01 All-in-one Systems 1 11-05-2007 8:28 AM
Old 01-12-2008, 9:43 PM   #1 (permalink)
Thanks: Gave 4, Got 0
Question Speaker cables for a HTSF-1300
I'll will be taking delivery of a HTSF-1300 system and from what I've read the it only comes with 2 x 4.5m speaker cables. I will need at lest double that amount for my set-up. can the cable be extended and where can I get the extention speaker cables from or can I just ditched the originals and use ordinary flat speaker cables?
would they be problems with the connectors?
Mush247 is offline   Reply With Quote
Old 01-12-2008, 9:48 PM   #2 (permalink)
Welsh Whirlwind's Avatar
Thanks: Gave 104, Got 214
Re: Speaker cables for a HTSF-1300
'Tis untrue it only comes with 4.5m cables. Fronts and sub 4.5m, rears approx 8m. But if that's not enough then yes, it's simple enough to extend them.
Samsung LE32R72B LCD; Harmony One; Sony HT-SF1200 Amp; Sony RDRHX870 DVD HDD; Tacima CS929 & PS3.
Welsh Whirlwind is offline   Reply With Quote
Old 01-12-2008, 9:59 PM   #3 (permalink)
So are you saying that the front and Sub has 4.5 each and the rear has 8m each, so do I get 5 lots of cables or I'm getting it all wrong?
Old 01-12-2008, 10:08 PM   #4 (permalink)
colspark's Avatar
Thanks: Gave 346, Got 403
You'll have 6 lots of cables. The speaker cable for the sub is attached already to the back of the sub. You'll then have a short one for the centre, and 4m ish for each of the fronts, and 8m ish for each of the surrounds. I'm saying "ish" because that's what i got with my 1200, as far as i know it's the same, give or take half a metre here and there, with the 1300...
as Welsh Whirlwind said, it's easy to extend them though.
there are so many things i would've done if it weren't for mornings and sobriety...
colspark is offline   Reply With Quote
Welsh Whirlwind (01-12-2008)
Old 01-12-2008, 10:11 PM   #5 (permalink)
Cheers Col, sorry forgot to mention centre speaker being short.
Mush247 (01-12-2008)
Old 01-12-2008, 11:00 PM   #6 (permalink)
colspark's Avatar
No worries buddy, easy to forget that one eh!
Old 01-12-2008, 11:10 PM   #7 (permalink)
Thanks all, the 8m should be enough.
Old 17-01-2009, 7:54 AM   #8 (permalink)
HI everybody,
do you think I can swap the front cable speakers for the HTSF1300.
Unfortunately my right cable (red connector) is only 3m and the left cable (white connector) is 4,5m. This is a problem for me as I need it longer for the right front speaker.
lakeone is offline   Reply With Quote
Old 17-01-2009, 12:18 PM   #9 (permalink)
RottenFox's Avatar
Thanks: Gave 445, Got 1,696
swap cables..if you only need 3m for the left of course?
XBL/PSN Gamertag - RottenFoxBreath
- The views i express are my own,and in no way represent the views of AVForums or affiliates -
RottenFox is offline   Reply With Quote
cables, htsf1300, speaker
[IMG] code is Off
