Re: Sony HT-SS1300
The TV will connect to the system with a standard pair of phono cables allowing you to listen the audio from whatever is on screen i.e the stereo signal from analogue or Freeview TV.
The xbox will be able to connect to the system an optical cable - this is what gives you 5.1 sound from your games or DVDs. I think the xbox upscales the picture to whatever output setting you have selected as your TV, but I haven't used the xbox as a DVD player for long enough so can't remember correctly.
I've never used (or seen) a V+ box, but I'm sure this also has an optical output for connecting to a surround system.
Are you telling me that this sucker is nuclear?!
