Re: Sharp ht-dv40h - help!
more than likely,if you have adjusted the volume/output levels,there is nothing to be done,as that sub is passive,isnt it(powered by the system).
so the hum will be part and parcel of the equipment,unfortunately.
what you could do,is phone sharp,and ask them,if its within specifications,as some people are more prone to certain noises,than others,and it may be you are just picking up on it more,now you are atuned to it.
XBL/PSN Gamertag - RottenFoxBreath Wii Code - 5320 0184 6511 5759
- The views i express are my own,and in no way represent the views of AVForums or affiliates -
