Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
Today's price checkPowered by
Sony DAV-DZ280
Sony HT-IS100
Panasonic SC-BT200
Panasonic SC-BT205
Sony DAV-DZ280
Sony HT-IS100
Panasonic SC-BT200
Panasonic SC-BT205
LG HT304SU
Samsung HT-BD1220
Panasonic SC-PT470
Samsung HT-Z220
Samsung HT-X720
Panasonic SC-PT170
 More...Prices updated November 24th at 11:30am and include delivery.
Sony HT-DDWG700 and HT-DDWG800 spaceman763 All-in-one Systems 16 01-09-2008 9:31 PM
Monster HTS1000 Home Theatre PowerCentre or Belkin PureAV Isolator Home Theatre SP mattj222 Interconnects, Speaker Cables and Switches 4 08-03-2008 3:57 PM
Sony HTK-215 home theatre kit fcca AV Amplifiers and Receivers 11 18-02-2001 3:01 PM
Sony htk-215 home theatre kit fcca Speakers 0 26-12-2000 11:29 PM
Closed Thread
Old 27-11-2008, 8:17 PM   #796 (permalink)
Thanks: Gave 1, Got 1
Re: Sony HT-DDWG800 Home Theatre Sys REVIEW
Got the system today and hooked it all up, but have one MASSIVE problem. When I plugged in the subwoofer the metal pin thats at the end of the cable broke off into the Audio Out subwoofer hole. Any idea's how to get this out again? Desperate for some help, as only just setup and already not working
Xbox 360 - Playstation 3 - Panasonic TH-50PZ80B - Sony HTDDWG800 - SKY HD - Dell Dimension 9200 WEI: 5.5 - Dell Vostro 1700 WEI: 5.1 - Samsung SM226BW - Dell UltraSharp 2208WFP
Quassimodem is offline
Old 27-11-2008, 9:10 PM   #797 (permalink)
Update on the situation. I have tried plugging in one of those red-white cables and it goes through and I can hear some bass. I assume that the red-white cable are obvious the wrong cable. Bit I do hear some bass, so the subwoofer must be working... Would that be correct I assuming so?
Old 27-11-2008, 9:32 PM   #798 (permalink)
lamboluke's Avatar
Thanks: Gave 58, Got 11
If the end of the cable has broken off the sub its self should still work... as its the connection thats broken. You might just need a replacement sub wire; but i'm not 100% sure if there are specific sub wires, but the red/white cables probably wont be suitable at a guess.
lamboluke is offline
Old 27-11-2008, 9:34 PM   #799 (permalink)
Thanks for that. The tip of the cable broke of in the amp itself.. But using the red/white cable there is some sort of noise..So it must still be fine. And will get myself another subwoofer cable (as they look pretty standard. The male bigger single rca plug..)
Old 27-11-2008, 10:00 PM   #800 (permalink)
lamboluke's Avatar
Best of luck anyways... When you say some sort of noise; is it bass or static? Does the sub make the correct noise that a sub should?
If you have no concerns and it sounds like it should i cant see there being a problem but i dont know that much re av. Still learning as we all are
Old 27-11-2008, 10:20 PM   #801 (permalink)
It makes the noise a sub should make (I think) as there's no static and you can hear faint sounds of the movile, song ect coming out of it...
Old 27-11-2008, 10:40 PM   #802 (permalink)
Thanks: Gave 0, Got 3
What settings do people use on the PS3 and AMP to get the best out of the 5.1 sound?
Also when playing a dvd on the PS3 any speech is really quiet, turning the volume up means music and sound effects are then to loud. Have to change the amp to 2CH. Anyone else have this problem.
Connection is through HDMI.
phardy is offline
Old 28-11-2008, 10:05 AM   #803 (permalink)
Hi! Everyone!
I have to silly questions to Sony HT-DDWG800 happy owners.
1. Did You have any trouble mounting speakers on the wall? Aren’t they too massive?
2. Central speaker is also can be wall-mounted, isn’t it?
3. Does the device really produce HD sound decoded in PS3?
thanks
dudisimo is offline
Old 28-11-2008, 1:14 PM   #804 (permalink)
mooperman's Avatar
Thanks: Gave 856, Got 256
Originally Posted by dudisimo View Post
Hi! Everyone!
thanks
not sure on 1 & 2 but i can confirm 3 is a huge yes...
Xbox 360 Tag - Original Moo ------- PSN Tag - Original-Moo
mooperman is offline
Old 28-11-2008, 3:25 PM   #805 (permalink)
RottenFox's Avatar
Thanks: Gave 444, Got 1,695
No,if its HD audio it will only be available from hdmi.
if its standard audio(say,from a dvd player or xbox 360,something liek that),use optical,for digital 5.1.
XBL/PSN Gamertag - RottenFoxBreath
- The views i express are my own,and in no way represent the views of AVForums or affiliates -
RottenFox is offline
Old 28-11-2008, 3:27 PM   #806 (permalink)
RottenFox's Avatar
DO NOT use red/white analogue audio leads,as sub cables.
at the very least, a yellow composite video cable will suffice,as it "should" be the same as a sub cable,that is, 75hms resistance.
as for plugging this in,into a broken cable,in the amp...get the remaining end out first..dont go shoving more into the hole,as you are now close to breaking it,and i guess that isnt covered by warranty.
Old 28-11-2008, 3:29 PM   #807 (permalink)
RottenFox's Avatar
why not just turn up the centre speaker,or manually set the speakers up/even carry out the auto cal again,...you do really need to RTFM!!
Old 28-11-2008, 3:30 PM   #808 (permalink)
RottenFox's Avatar
Hi! Everyone!
thanks
1. not with a decent set of mounts.
2. you could mount it with a larger bracket,or two small ones,but more or less you might have to screw something to the actual speaker,as it doesnt contain a screw hole.
Old 29-11-2008, 12:58 PM   #809 (permalink)
Visor's Avatar
Thanks: Gave 3, Got 9
Originally Posted by Geezer69 View Post
Quick question guys - thinking of getting this very soon. Can anyone tell me the height from the bottom up, rear speaker screw hole for mounting to stand. I don't really want to get rid of the stands I only bought 5 months ago. Cheers in advance
67mm to the centre of the screwhole.
Visor is offline
Geezer69 (01-12-2008)
Old 30-11-2008, 6:19 PM   #810 (permalink)
Thanks: Gave 3, Got 0
Established it was the optical cable that was faulty, got a new one and all good! Thanks again kevicles! Very happy now
blik... is offline
home, htddwg800, review, sony, sys, theatre
[IMG] code is Off
