Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
Today's price checkPowered by
Sony DAV-DZ280
Panasonic SC-BT200
Sony HT-IS100
Panasonic SC-BT205
Sony DAV-DZ280
Panasonic SC-BT200
Sony HT-IS100
Panasonic SC-BT205
LG HT304SU
Samsung HT-Z220
Panasonic SC-PT470
Samsung HT-BD1220
Samsung HT-X720
Panasonic SC-PT170
 More...Prices updated November 24th at 6:30pm and include delivery.
Sony HT-DDWG700 and HT-DDWG800 spaceman763 All-in-one Systems 16 01-09-2008 9:31 PM
Monster HTS1000 Home Theatre PowerCentre or Belkin PureAV Isolator Home Theatre SP mattj222 Interconnects, Speaker Cables and Switches 4 08-03-2008 3:57 PM
Sony HTK-215 home theatre kit fcca AV Amplifiers and Receivers 11 18-02-2001 3:01 PM
Sony htk-215 home theatre kit fcca Speakers 0 26-12-2000 11:29 PM
Closed Thread
Old 20-11-2008, 10:41 AM   #751 (permalink)
Thanks: Gave 1, Got 0
Re: Sony HT-DDWG800 Home Theatre Sys REVIEW
sorry for buttin in on the on going questions but im ready to purchase a home theatre system right now and im torn between the DDWG800 and the yamaha av63 package.it the sony better ? and is it worth me spending the extra 50 quid on the sony ?.
icewinder is offline
Old 20-11-2008, 1:56 PM   #752 (permalink)
RottenFox's Avatar
Thanks: Gave 445, Got 1,696
Yes,it is.
XBL/PSN Gamertag - RottenFoxBreath
- The views i express are my own,and in no way represent the views of AVForums or affiliates -
RottenFox is offline
icewinder (20-11-2008)
Old 20-11-2008, 2:01 PM   #753 (permalink)
and last question , would that be my best option with a max of £250 to spend ?.
Old 21-11-2008, 12:02 AM   #754 (permalink)
godfarter's Avatar
Thanks: Gave 5, Got 58
hmmm...i think THAT decision ultimately comes down to your own
put it this way, at £250 for all the features and quality of the brand, the sony ht-ddwg800 is a bargain for many of those including me that bought it at that particular time over the past few months
personally i didn't really have a budget, just that i did not want to overspend so i was pleasantly surprised when i first saw the price of the ddwg800 along with all the functions...
Toshiba37WLT68,SKYHD,SonyHT-DDWG800,HPMediaCenter7350 Pent.D,HPW2408H Monitor, NoxoniRadio,Nabaztag/tag,Wii,PS3,SlingboxSOLO,SonyKLV-40X200A,LogitechHarmony885,DellDimension9200, CanonEOS5DMkII,PanasonicLumixTZ7, StarhubHubstationHD, D-LinkDIR-685, Slingcatcher, iMac
PSN: f-a-r-t-f-a-c-e
godfarter is offline
Old 21-11-2008, 12:12 AM   #755 (permalink)
godfarter's Avatar
Originally Posted by ohm-ed View Post
Quick question there lads how many channels does this have would i be able to hook up a wii(component), a pc (hdmi), an xbox 360 (component & optical) a HD digital entertainer (HDMI) and a set of turntables (phono cable) all at once?? just looking at the rear of it and seems like it has 3 hdmi and 3 components but they are named the same as each other??does this mean you can only use one or the other?? also if you are using component cables can you buy component to component cables and where??
yep you gotta use one or the other - the unit has a maximum of 4 channels (max 3HDMI, 1 Component and vice versa max 3 Component, 1 HDMI) so from your set up you would have 2 hdmi, 2 component and you need to get an extra cable of each for output to your television.
your turntable phonos can go into the SA-CD/CD inputs on the back and you are all set.
just a question your pc is carrying both audio and video through HDMI? if so then i think all should be good but if it is just video then you got to think about how you plan to deal with the pc audio
component to component cables easily find them on ebay
ohm-ed (24-11-2008)
Old 21-11-2008, 10:28 AM   #756 (permalink)
thanks for the adivce chaps i've plumpt for the sony
Old 21-11-2008, 6:29 PM   #757 (permalink)
Visor's Avatar
Thanks: Gave 3, Got 9
Originally Posted by lucaballa View Post
They just told me that the problem is in the PS3, and not in the receiver... very strange anyway cause I never had this problem before with PS3 connected directly to the TV via HDMI...
That's a bummer. Can't you take it back and get a refund?
It's the same with mine - it never used to do this with the PS3 connected directly to my 50PZ80 plasma.
Griz managed to get a replacement, but he said the new unit displayed the same fault. Maybe the issue lies elsewhere?
Lucaballa, what TV do you have?
Visor is offline
Old 21-11-2008, 8:41 PM   #758 (permalink)
Thanks: Gave 1, Got 1
Bought my Sony - HT-DDWG800 Home Cinema System today...
Xbox 360 - Playstation 3 - Panasonic TH-50PZ80B - Sony HTDDWG800 - SKY HD - Dell Dimension 9200 WEI: 5.5 - Dell Vostro 1700 WEI: 5.1 - Samsung SM226BW - Dell UltraSharp 2208WFP
Quassimodem is offline
Old 21-11-2008, 10:38 PM   #759 (permalink)
lamboluke's Avatar
Thanks: Gave 58, Got 11
Goood choice there !!
lamboluke is offline
Old 23-11-2008, 5:58 AM   #760 (permalink)
Like Visor said I got my unit replaced from the retail store - tested immediately and the problem was still there. I have a Panasonic 50PZ800 so I think the problem lies with a HDMI conflict between the DDWG800 and 50PZ800. I never had a problem with the PS3 direct to the plasma - I suspect the receiver is at fault and is sending the incorrect signal.
I have not had the problem much recently, and when it does happen either cycling the receiver inputs or turning the screen off then on (which causes the receiver to resync the HDMI signal) will fix the problem. I have decided to live with the problem, even though it is annoying. I am unhappy that using all new HDMI 1.3 spec devices still ends up with HDMI connectivity problems
Would be interesting to know if anyone else is using PS3 / DDWG800 (or other sony receiver) / panasonic PZ80 (or PZ800) series plasma and if they are having problems too??
griz is offline
Old 23-11-2008, 12:42 PM   #761 (permalink)
hi there everyone just received my new system this week and so far very inpressed with it. Just a few questions to see if im getting the best from it. I have it rigged up to my samsung series 6 tele through hdmi .my ps3 is connected to reciever in same way. sky+ is by scart to tele and optical to reciever. i also have a wii which is just connecyted to the tv at the mo.
Is it possible to connect the wii to this system for both image and sound if so what is the best way.
What are the best settings for this system in concern to sky+ and my ps3 so i am getting the best from them.
Also in my opinion the sub doesnt seem as bassy as it should even wen it is fully turned up .Is there something im doing wrong.
And finally is it possible to change channels using the remote. just now all i can do is get the sound but not the image using the reciever remote. so wen i use either sky or my ps3 i have to change channel with tele remote then select the sound using the reciever remote.
Any advice assistance would be much apprecieted
kevicles is offline
Old 23-11-2008, 6:01 PM   #762 (permalink)
I've installed the system this morning and am very happy with it Both the HDX-1000 mediacenter and Xbox360 work perfectly with the optical in connections. I've watched The Island in 1080p with DTS and was very, very impressed by the system. Excellent bang for the buck!
Thanks for the advice and many thanks to the threadstarter for the excellent review!
Okkie is offline
Old 23-11-2008, 8:13 PM   #763 (permalink)
r4zb3rry's Avatar
Thanks: Gave 71, Got 110
Just wanted to confirm before I purchase so, I can get the cables at the same time.
Hooking this up to SKY HD and PS3, need an HDMI for each to the Amp then one to the TV, also can I use an Optical cable from each device to the amp for Audio?
Also, how vital is the speaker positioning, as the shape and layout of my lounge does not really lend itself to exact 'four corners' positioing?
R4z
PSN: EvilFruits_R4z
*DNS 80710102 Error - Try This!* :
r4zb3rry is online now
Old 23-11-2008, 8:20 PM   #764 (permalink)
hi just wondering when i play my music i have stored on my ps3 through the system i can only seem to play it in surround mode . it is connected through hdmi cable to the reciever. i am wondering how you can play it in two channel stereo mode as it dont seem to work when i press the button on the remote and just says not used.
any help much appreciated
kevicles is offline
Old 23-11-2008, 8:36 PM   #765 (permalink)
lamboluke's Avatar
R4z
HDMI as far as i'm aware will carry both audio and video so no need for hdmi and optical.
As for speaker positioning, i'd just experiment with your room layout and try to get the best out of your room layout.
home, htddwg800, review, sony, sys, theatre
[IMG] code is Off
