3.5 million visitors each month
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
Today's price checkPowered by
Sony DAV-DZ280
Panasonic SC-BT200
Panasonic SC-BT205
Sony HT-IS100
Sony DAV-DZ280
Panasonic SC-BT200
Panasonic SC-BT205
Sony HT-IS100
Samsung HT-Z220
Yamaha YSP-600
Panasonic SC-PT470
Samsung HT-BD7200
Samsung HT-BD1220
Samsung HT-X720
 More...Prices updated November 8th at 3:30pm and include delivery.
Sony HT-DDWG700 and HT-DDWG800 spaceman763 All-in-one Systems 16 01-09-2008 9:31 PM
Monster HTS1000 Home Theatre PowerCentre or Belkin PureAV Isolator Home Theatre SP mattj222 Interconnects, Speaker Cables and Switches 4 08-03-2008 3:57 PM
Sony HTK-215 home theatre kit fcca AV Amplifiers and Receivers 11 18-02-2001 3:01 PM
Sony htk-215 home theatre kit fcca Speakers 0 26-12-2000 11:29 PM
Closed Thread
Old 23-10-2008, 5:05 PM   #631 (permalink)
RottenFox's Avatar
Thanks: Gave 419, Got 1,648
Re: Sony HT-DDWG800 Home Theatre Sys REVIEW
Originally Posted by chris_lufc View Post
no probs, if yours arrives tomorrow you may have it set up before me and i've had mine since monday! mine won't be set up until saturday but hopefully then I will be watching a BRand checking out the sound! Just a quick question to anyone who has set this up. The receiver is too big to go on one of my shelves in my unit and I was thinking as an option of placing my samsung LE26R87 on top but was a little sceptical about weight and overheating the reciever as it would block the vents. If you need an idea of the mess I have at the moment heres a picture (excuse the bad quality, taken on my iphone)
http://i291.photobucket.com/albums/l...1/IMG_0043.jpg
i wouldnt put the tv on it,due to heat/weight and instability issues.
a new tv unit or a small side unit would be better i think..
or if you wanted to ,just leave it where it is.
if you wanted a cheap tv stand,what about this one:
Vistron 3-Tier Glass TV Stand For 42" to 60" screens Clear Glass and Chrome Finish - Ebuyer
£29.99 and pretty much the same size as you have now,but with the lower shelf having more clearance.
XBL/PSN Gamertag - RottenFoxBreath
- The views i express are my own,and in no way represent the views of AVForums or affiliates -
RottenFox is offline
chris_lufc (23-10-2008)
Old 23-10-2008, 6:14 PM   #632 (permalink)
Thanks: Gave 25, Got 15
Originally Posted by RottenFox View Post
are both setup for audio over hdmi as PCM?
if so, the only problem you will have is with DTS on the 350,as the player and receiver dont decode it,so you will just get standard DTS(still sounds great though)
I've got the 350 setup to auto. The sound is good I was just wondering if I had it setup wrong. I'll have another look at it tonight.
Just to confirm what should I ideally have it set on?
TV: Panasonic TX-P50G10 Blu: Sony BDP-S350 AV: Sony HT-DDWG800 HD-DVD: Toshiba EP30 Other: XBOX 360 - Aluminum iMac 24" - MacBook - iPhone 3GS - Acoustic Energy Aego-M
leckie is offline
Old 23-10-2008, 10:03 PM   #633 (permalink)
lamboluke's Avatar
Thanks: Gave 57, Got 11
Originally Posted by leckie View Post
I've had my DDWG800 for about a week however tonight was the first night I've had it fully setup. Got all the speakers mounted on the walls using the fabled Mikomi wall mounts from Argos that I know some people would like some info on.
The mounts are made from strong plastic with a simple bolt for movement. They fit the front speakers perfectly however I had a saw a couple of cm off the rear ones to make them fit correctly (took a few minutes max).
All in all they do the job perfectly and hold the speakers securely and don't stick out like a sore thumb so if you want to wall mount your speakers I would definitely recommend them.
If anyone has any questions about them ask away.
Can you please elaborate, possibly pictures or them mounted also?
Thanks.
lamboluke is offline
Old 24-10-2008, 1:05 AM   #634 (permalink)
I'll pull them down sometime tomorrow and grab a quick pic.
leckie is offline
Old 24-10-2008, 1:30 AM   #635 (permalink)
Thanks: Gave 33, Got 1
Are these speaker stands ok for this system?
SONY WSFV10 SPEAKER STANDS (pair) [WSFV10] - £29.00 : Total Digital - The Home of Audio Visual Entertainment
Sorry don't know how to put a link in with out having to put the full code wish I knew how to just say these or here and get the link to the page.
Richardod is offline
Old 24-10-2008, 9:24 AM   #636 (permalink)
Thanks: Gave 2, Got 1
Hey all,
Is it possible to connect the system up and just use the front speakers? I have to wait until my mate can mount the rear speakers and not going to attempt it myself so thought I would just get the front ones going, is that possible?
roakes is offline
Old 24-10-2008, 12:40 PM   #637 (permalink)
Well my sound system came yesterday
Word of warning (and I should have known better) - Pixmania did not send any Euro Converter plug (not one!!) so had to run out to the shops to grab a second one.
Otherwise I'm impressed (have only tested a Transformers Blue Ray). I will put up a mini review after the weekend when I set it up properly with everything working
PurpleMonkeyDW is offline
Old 24-10-2008, 12:48 PM   #638 (permalink)
RottenFox's Avatar
Originally Posted by roakes View Post
Hey all,
yeh,you could do,but i would set up all the speakers,and just have the rears on the floor in the meantime,to make sure they work,and to get ahead on the mounting plan.
Old 24-10-2008, 12:59 PM   #639 (permalink)
Thanks: Gave 31, Got 10
glad to see yours arrived. I thought the same about the plug converter but it was right at the very bottom of mine underneath some of the polystyrene so just double check. If you haven't received one then that is a tad unlucky.
Samsung LE26R87, PS3 80GB, xbox 360, Seagate 320GB EXT HDD, Samsung DVDHD870, Sony HT-DDWG800, Sky TV.
chris_lufc is offline
Old 24-10-2008, 1:57 PM   #640 (permalink)
Here is the picture for anyone that would like to see it.
You will see by looking at the top and bottom of the bracket where I have had to saw at the top. This isn't needed with the front speakers as they don't have to protrusion for a screw.
Excuse the quality of the picture I had to use my phone.
leckie is offline
lamboluke (25-10-2008)
Old 25-10-2008, 4:07 PM   #641 (permalink)
lamboluke's Avatar
Thanks for posting that picture. Just had a look at them on the argos website and they seem to have poor reviews so i'm put off a little if i'm honest. Would you recomend them for these particular speakers though as your the best person to ask for as i would be fitting them to these speakers if i did buy the mounts.
Do they sag at all? If you recomend them i'll probably take a shot with them and hopefully i'll be pleased
Thanks.
Old 25-10-2008, 5:30 PM   #642 (permalink)
godfarter's Avatar
Thanks: Gave 5, Got 56
As leckie said, he had to saw off the top of the bracket so that the mounting bracket could fit the rear speakers, so unless you are as handy with a saw then by all means
Otherwise I think you are better off getting something else. Amazon has quite a few to choose from, some like the Omnimount £28.99 or the B-Tech BT33/W £2.72 which also includes adaptors for key hole, single point and dual point speaker fittings. I don't use speaker wall-mounts so I'm no expert but I use the B-Tech BT11 Speaker stands and the adaptors which they included seem to do the job!
This is a picture of how the adaptors look when mounted with speaker stands...maybe you can email B-tech and ask if these are the same adaptors provided for the wall mounts and if so you can make your own decision from there!
Picture of DDW800 Speakers Mounted to FLOOR STANDS
Toshiba37WLT68,SKYHD,SonyHT-DDWG800,HPMediaCenter7350 Pent.D,HPW2408H Monitor, NoxoniRadio,Nabaztag/tag,Wii,PS3,SlingboxSOLO,SonyKLV-40X200A,LogitechHarmony885,DellDimension9200, CanonEOS5DMkII,PanasonicLumixTZ7, StarhubHubstationHD, D-LinkDIR-685, Slingcatcher, iMac
PSN: f-a-r-t-f-a-c-e
godfarter is offline
Old 25-10-2008, 6:14 PM   #643 (permalink)
lamboluke's Avatar
Thank you very much for the reply godfarter.
I quite like the look of the b-tech bt33's. Plus saves me having to buy a saw
I think when i order the Sony HT-DDWG800 off pixmania i will order the B-tech's in black with their universal mounting options and adjustability suits me perfectly.
Plus quoting from pixmania
The BT33 / BT332* are the Universal Wall Mounts for small Home Cinema and Surround Satellite Speakers. They are designed for speakers with a weight up to 3.5Kg (7lbs) with the following fittings :Single Threaded Insert, Dual Threaded Insert, Keyhole InsertThe BT33 / BT332 come complete with full hardware and fixings kit and are easy to mount. Options AvailableSingles:Black BT33BSilver BT33SWhite BT33Twin packs:Black BT332 Silver BT332SWhite BT332W
So i'll go with those i think
Old 25-10-2008, 7:13 PM   #644 (permalink)
mooperman's Avatar
Thanks: Gave 813, Got 248
How do fella's,
finally got round to updating my setup post with this kit in so have a look and comment away...
Moopermans Setup
M
Xbox 360 Tag - Original Moo ------- PSN Tag - Original-Moo
mooperman is offline
Old 25-10-2008, 11:39 PM   #645 (permalink)
Finally got mine set up today. It took a while and I had to go buy some more speaker wire as the wire supplied was quite short. So far I have been pretty impressed with the sound from the ps3 and 360 but tomorrow will be the big test with an actual blu-ray film, probably iRobot. Anyway, thanks for all the help everyone has provided and I'm sure I will try and help anyone who needs it and anyone thinking of buying the system.
home, htddwg800, review, sony, sys, theatre
[IMG] code is Off
