AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 07-05-2008, 12:31 PM   #1 (permalink)
Thanks: Gave 9, Got 17
All in one unit.
Hi all,
This may not be the best forum for this question but....here it goes .
I currently have an XBox 360, PS3, wii and ps2 connected to my TV which does the audio output thru inbuilt speaker. My TV doesnt have a Headphone socket, which i really need. What i was hoping to find is a really cheap unit that can take audio via Optical and Phono and has a headphone socket.
Any recommendations welcome :-)
Wii Code : 1594 2411 3960 1362 Mart kart: TBC PSN: gavinb80 Xbox Live: gavb2k7
PS3(40gb) | Xbox Elite (120gb) | Wii + Wii Fit :-) | PS2 | Virgin V+ XL package | Hanspree 32" HDTV
gavbeer is offline   Reply With Quote
Old 07-05-2008, 12:44 PM   #2 (permalink)
Thanks: Gave 1, Got 14
Re: All in one unit.
I use logitech z5450 review on trustedreviews
It has 2 optical, 1 coaxial, 1 x 5.1 analog / 3 stereo analog inputs.
I have in past used it with sky plus and xbox 360, currently only using it with xbox 360. The rear speakers are wireless (still need to be powered though)
you can buy wired ones cheaper though.
there is also a pioneer speaker kit for similar purpose.. more on it here or you can do a google search
hermitd is offline   Reply With Quote
gavbeer (07-05-2008)
Old 07-05-2008, 12:57 PM   #3 (permalink)
thanks for the quick response,
the Pioneer one doesnt look like it has a Headphone socket on it?
*edit - on closer inspection, i can see a headphone socket on the logitech z5450 either :-)
Old 07-05-2008, 1:07 PM   #4 (permalink)
Thanks: Gave 4, Got 3
My logitech z5300 does have a headphone jack, so it would surprise me a lot if the z5450 doesn't.
hogl is offline   Reply With Quote
Old 07-05-2008, 1:08 PM   #5 (permalink)
just looked on Richer Sounds website, would a Yamaha RXV361 do what i need?
Old 07-05-2008, 1:10 PM   #6 (permalink)
ah ok,
was just looking at images on THIS page and they dont show any headphone sockets, apart from what apear to be some kind of PC input?
Old 07-05-2008, 1:19 PM   #7 (permalink)
well it shows 3 stereo input which is for analog 5,1
the 5.1 is option and can be used as 3 x Stereo input so your headphone input is fine
from trusted reviews site - Page 2 (below sub woofer pic)
There are also three analogue 3.5mm inputs. A switch on the rear enables this to be configured as three separate stereo inputs or as a single 6-channel direct input from a PC sound card.
Old 07-05-2008, 1:22 PM   #8 (permalink)
ah ok,
Apparently it is located on the side. At least that's what I gathered from skimming google
Old 07-05-2008, 1:22 PM   #9 (permalink)
many thanks for all your help
Old 07-05-2008, 1:25 PM   #10 (permalink)
not to worry mate... i have this speakers and they are good for the purpose... i am not a massive audiophile and do not like to spend hundreds and hundreds on kit i would rather have a nice value for money kit which logitech definitely is
also from the review:
Thanks to rear speakers that only require power and receive their signal wirelessly Logitech has produced a set of surround sound speakers that have a vastly increased chance of gaining the WAF (Wife Acceptance Factor).
This was a deal maker in my case.. wife would have veto'd the plans if there were too many wires going around
Old 07-05-2008, 1:32 PM   #11 (permalink)
excellent :-)
just got to convince the g/f now
Old 07-05-2008, 1:34 PM   #12 (permalink)
Thanks: Gave 31, Got 245
The Z5400/5450 (- the latter being exactly the same apart from the wireless rear surround speakers) both have headphone sockets - it's on the left hand side (a 3.5mm output socket). Otherwise perhaps you could consider second hand as a way of keeping the cost down. Connections on the back are the two optical digital inputs, one coaxial plus a multi option connection that can either be used for separate stereo sources or grouped together for multi-channel analogue input (from a PC sound card for example).
The Yamaha RXV361 ought to work, although without surround speakers connected it's going to give you errors - it might be necessary to set it up in two channel mode within the basic amp setup with a budget pair of stereo speakers.
Robert
Panasonic TH37PX70 TV ~ Panasonic PT-AE100E Projector ~ Yamaha RXV1700 AV Receiver ~ Momitsu DVD-V880 DVD ~ Toshiba HD-D1 ~ Canton Movie 150-QX speakers ~ PS3 (Japanese) ~ XBOX 360
rwniel is offline   Reply With Quote
Old 07-05-2008, 1:51 PM   #13 (permalink)
Robert
Excellent, thanks, i'd seen the Yamaha and a Sony STR-DE400 at Richer sounds, both quiet cheap, only issue then i could see with the Logitech one could be that it needs to have an xbox, wii, ps2 and ps3 connected and it doesnt look like it'd hae enough connections
Old 07-05-2008, 2:16 PM   #14 (permalink)
Thanks: Gave 4, Got 13
Yeah with that many inputs you may be better off geting a budget seperates system as Robert said. Second hand is a good option. Have a look in the classifieds and auction sites, see if you can get a good deal on an amp and speakers. You'll more than likely get better sound per pound that way
2003bluecat is online now   Reply With Quote
Old 07-05-2008, 2:21 PM   #15 (permalink)
Thanks: Gave 38, Got 46
Yes it would do the job just fine. The RXV361 as 2 optical inputs, 1 co-axial input and analogue/component inputs for just about everything, plus an headphone socket.
I've got my TV, 360 and BDP-S300 hooked up to mine and i'm perfectly happy with it because for the price it's a great buy.
chrisjohnp is offline   Reply With Quote
unit
[IMG] code is Off
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Do you own a NVA unit? Do you like it? ForestGump Hi Fi Systems and Separates 6 03-05-2008 7:27 AM
Corner unit or shallow unit needed Widge AV Stands, Cabinets, Seating and Furniture 18 03-12-2007 11:54 AM
Where can i get a unit like this? HighQ How do I get the components of my home cinema to to work together? 6 15-02-2007 8:10 AM
Where to get a Motorized Alpine unit + DVD unit + roof mounted screen fitted in North chrisjoanne Portable DVD and Media Players and Recorders 1 11-03-2004 4:45 PM
Power Supply Unit From Pricejapan unit-Just to be sure! Comer DLP, LCD and D-ILA Projectors 6 13-02-2003 7:28 PM
AV ForumsOptimised for Firefox.
