AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 06-05-2008, 8:53 PM   #1 (permalink)
Thanks: Gave 6, Got 6
Pardon my ignorance....whats the difference between the Sony HTSF1300 and DAVDZ860
I'm a buffoon when it comes to things like this....to me it looks like they do exactly the same things....is this correct or am I a grade A muppet?
TA
Jimb077 is offline   Reply With Quote
Old 06-05-2008, 9:01 PM   #2 (permalink)
kentish_lad's Avatar
Thanks: Gave 25, Got 205
Re: Pardon my ignorance....whats the difference between the Sony HTSF1300 and DAVDZ86
The 860 is a complete DVD amp and speaker combo , the other is an amp and speakers without DVD player
kentish_lad is online now   Reply With Quote
Jimb077 (06-05-2008)
Old 06-05-2008, 9:03 PM   #3 (permalink)
Ah.....cheers mate!!
I've been doing soooo much researching recently that I was just lookin at the specs of the two and none of it was making any sense!!
Old 06-05-2008, 9:08 PM   #4 (permalink)
The 1300 is a better option but you would need a DVD player to connect to
Old 06-05-2008, 9:12 PM   #5 (permalink)
Why would this be better?
Would the 1300 upscale DVDs from a standalone DVD player?
Sorry for my stupidity....I'm new to all this!!
Old 06-05-2008, 10:10 PM   #6 (permalink)
Better connectivity for other sources
No
Old 06-05-2008, 10:12 PM   #7 (permalink)
No
Thats cleared that one up then!!
Old 24-07-2008, 7:34 PM   #8 (permalink)
Thanks: Gave 6, Got 2
Didnt want to start a new thread, so I'll ask here. If I purchase a SONY HTSF1300, would I be able to plug the speakers into a seperate amp instead of the one supplied?
fearlessturk is offline   Reply With Quote
Old 24-07-2008, 7:46 PM   #9 (permalink)
You could but you would need an 'active' SUB, the one in the sony 1300 package is 'passive'
Better off buying just a speaker package to go with a separates amp
Old 24-07-2008, 8:09 PM   #10 (permalink)
Thanks for the reply.
I plan on buying a Sony 5300ES amp to plug all my stuff into. Do you know where I could buy the same speakers that are on the HTSF1300 seperately?
Thanks again.
Old 24-07-2008, 8:40 PM   #11 (permalink)
Thanks again.
I dont think you can buy them seperately, have a look here for speaker deals
Canton Powerbuy for AVForum members
fearlessturk (24-07-2008)
Old 24-07-2008, 9:18 PM   #12 (permalink)
Thanks.
Old 25-10-2008, 12:18 PM   #13 (permalink)
TA
The first one doesent have wirelless in rear speakrs... and Z860 has.
Master Dragon is offline   Reply With Quote
davdz860, difference, htsf1300, ignorancewhats, pardon, sony
[IMG] code is Off
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Sony ES Amps Whats The Difference? patton Integrated AV Amplifiers and Receivers 2 22-02-2007 4:15 PM
whats the difference between sony 46x and 46w? nawfal LCD Televisions 0 22-09-2006 9:20 AM
Sony U and S series-Whats the difference ?. Blake77 LCD Televisions 2 25-08-2006 7:26 AM
Whats the difference between Sony KDL- S26 and KLV- V26? Danser LCD Televisions 3 15-12-2005 4:40 PM
Sony DCR-IP1 or DCR-IP1E? Whats the difference? Orsky Camcorders and Video Editing 4 06-01-2005 12:50 PM
AV ForumsOptimised for Firefox.
