AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 06-05-2008, 8:19 PM   #1 (permalink)
Thanks: Gave 19, Got 18
Setup help for a newbie!
Hi all, would be very grateful if someone could help me with a setup I've put in for the parents, not sure if I've got it plugged in and if someone could suggest how to connect it properly I would be very grateful. I have:
Samsung 32" LCD HDTV with optical port
Sony HTSS1100 Home Cinema Kit (Received today)
Sky Box (Thompson one no optical port)
Samsung DVD Recorder with Optical port.
Any idea how I should connect all of these to the amp? I've currently got the Sky and DVD recorder plugged in via scart and an optical cable from the TV to the amp. I get surround on Sky which is great but why is it only coming out in 2 channel sound or Pro Logic II? Does a normal Sky box not output true 5.1? if so how? Also to connect my DVD recorder to the amp for movies etc do I need another optical cable for this? I'm a bit confused so any help would be great! Thanks!
Samsung 40" A656 1080p HDTV, Sony HTSF1000 5.1 Cinema Kit, Xbox 360 Elite, Nintendo DS Lite, Sony Playstion 3, Samsung NC10 Netbook
XBL Gamertag: Spikecast
PSN ID: Spikecast
spikecast is offline
Old 06-05-2008, 9:01 PM   #2 (permalink)
ijd
Thanks: Gave 91, Got 142
Re: Setup help for a newbie!
for 5.1 you will have to connect using optical or co ax as only these carry digital signal, or if your amp has the capability you will see inputs for each individual channel, this will also give you 5.1 but as an analogue signal used on early amps.
to get 5.1 from sky you will need sky+ or sky hd as only these have the optical required.
please dont start your paragraph or sentence with BASICALLY
http://www.speedtest.net/result/177388255.png
ijd is offline
Old 06-05-2008, 9:48 PM   #3 (permalink)
Thanks we have Sky HD in the other room which we got 5.1 from but this is just bog standard Thompson "Sky" box with Sky lit up in the blue on the front. So are you saying I'm stuck with Dolby Pro Logic II then on this setup? Thanks.
PSN ID: Spikecast
Old 06-05-2008, 10:02 PM   #4 (permalink)
kentish_lad's Avatar
Thanks: Gave 25, Got 192
With a standard sky box you will get 2 channel stereo only, which is processed by the amp to give some sort of surround, but it wont be 5.1
kentish_lad is offline
Old 06-05-2008, 10:49 PM   #5 (permalink)
Thanks for the help. We will probably get it replaced with a HD box eventually but not until the prices come down.
PSN ID: Spikecast
newbie, setup
[IMG] code is Off
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Newbie! help! av setup. Allenwhite78 LCD Televisions 7 02-10-2007 3:38 PM
Newbie with New setup - What to get pody Integrated AV Amplifiers and Receivers 2 19-09-2007 11:16 AM
2.1 Newbie Setup devilish_nitro Speakers 1 28-03-2007 10:16 PM
Newbie help (2.1 setup) ytrebil Speakers 0 15-05-2006 1:00 PM
Newbie Setup manny_brown DLP, LCD and D-ILA Projectors 1 08-11-2005 8:53 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
