Re: Help needed with setup of Panansonic SA-HT 900
make sure all the panasonic's speakers are the same volume,if you can adjust them.
make sure the 360 is set to "dolby digital 5.1" out.
also check that you havent picked some sort of effect on the panny,like theatre,hall,etc.
finally,go into the in-game audio options,and turn down the music,and turn up the speech,if it bothers you..
thats what the options are there for,not everyone has it set to default.
these are there for a purpose,and you need to use the more than likely.
XBL/PSN Gamertag - RottenFoxBreath Wii Code - 5320 0184 6511 5759
- The views i express are my own,and in no way represent the views of AVForums or affiliates -
