AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 05-05-2008, 10:56 AM   #1 (permalink)
speaker connections
I am thinking of upgrading my system with a new LCD tv; the Panasonic Viera TX-37LZD70. However, I need to update my surround sound too and I could do with some advice. I currently have a Sony DAV-s550 all in one. Since the satellite speaker cables are all nicely hidden in the walls etc, I don't really want to rip them out and redecorate. However, they use a special sony plug into the back of the DAV-s550 amplifier. If I upgrade the amplifier, could I simply change the plugs on the ends from the sony ones; then plug straight in to the new amp?? If so, any recommendations on what plugs to use??
The 'sub' is a passive type so I plan on buying a new 'active' one. Again, any recommendations. Needs to be cheap by most of your standards...ie £150 ish!!
I would also like recommendations on the amplifier too (maybe £200 ish)
Many thanks
clangstone is offline   Reply With Quote
connections, speaker
[IMG] code is Off
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Speaker Connections steveianson Integrated AV Amplifiers and Receivers 3 10-04-2008 9:46 AM
Speaker connections for TV Dave911 Interconnects, Speaker Cables and Switches 0 13-06-2005 6:01 PM
which speaker connections paulsgolding Interconnects, Speaker Cables and Switches 8 26-06-2004 10:34 AM
Help with speaker connections to PC X-Man Computer Systems 0 26-02-2003 10:17 PM
speaker connections go5 Speakers 7 08-04-2002 8:28 AM
AV ForumsOptimised for Firefox.
