AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 04-05-2008, 1:56 PM   #1 (permalink)
Extending cables, help required.
Greetings.
This is my first post so please be gentle.
I have just purchased a Sony DAV-IS10 and I am having cable troubles,
the cable from the control unit (25pin) that goes into the sub woofer is not long enough, has any one got any idea if it is possible to get a M/F extension.
I have the control unit one side of a door and the sub woofer is on the other so I need a 6 metre M to F cable.
All suggestions gratefully received.
Bob M.
Bob M is offline   Reply With Quote
Old 06-05-2008, 8:06 AM   #2 (permalink)
Thanks: Gave 5, Got 0
Re: Extending cables, help required.
I think you are out of luck.
RSHERMAN112 is offline   Reply With Quote
Old 06-05-2008, 6:29 PM   #3 (permalink)
RottenFox's Avatar
Thanks: Gave 177, Got 1,036
proprietary fitting+sony=no.
XBL/PSN Gamertag - RottenFoxBreath Wii Code - 5320 0184 6511 5759
- The views i express are my own,and in no way represent the views of AVForums or affiliates -
RottenFox is online now   Reply With Quote
cables, extending, required
[IMG] code is Off
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Extending speaker cables bravogolf Interconnects, Speaker Cables and Switches 1 11-03-2008 3:02 PM
Extending Sky + Cables leeds123 Sky and Sky+ 1 26-12-2007 10:59 PM
Extending Sky+ cables - HELP!!! bsdbm Sky and Sky+ 16 29-11-2007 10:51 AM
Extending Xbox 360 cables to TV leruzin Xbox 360 5 09-08-2007 7:00 PM
Extending sky cables Puzzler Sky and Sky+ 7 15-05-2007 1:18 PM
AV ForumsOptimised for Firefox.
