AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 02-05-2008, 4:52 PM   #1 (permalink)
Tall Rears and Small Fronts !
Guys
Decided I will be hanging the tele on the wall so I think some small fronts either side would look good. On the rears, I dont fancy putting them on the wall because of where we sit so need some tall boys.
Does anyone know of any decent system for approx 250-300 tops with small fronts and tall boy rears (or shall I purchase some stands?) I think I prefer an all in one as I need a new DVD player also.
I have a Samsung 46" with loads of HDMI slots. Any ideas?
WazKayani is offline   Reply With Quote
Old 02-05-2008, 7:25 PM   #2 (permalink)
RottenFox's Avatar
Thanks: Gave 177, Got 1,036
Re: Tall Rears and Small Fronts !
most work the other way round..
why not just try to look around for a system,with smaller speakers all round.
XBL/PSN Gamertag - RottenFoxBreath Wii Code - 5320 0184 6511 5759
- The views i express are my own,and in no way represent the views of AVForums or affiliates -
RottenFox is offline   Reply With Quote
Old 02-05-2008, 7:55 PM   #3 (permalink)
Mmm...the problem is
1. Missus doesnt want cables up the wall
2. The left wall is a little way off so I dont have a corner I can mount the rears on (unless I can find some decent speaker stands).
I do like the new Sony HT SF-1300.
Old 03-05-2008, 12:06 PM   #4 (permalink)
Thanks: Gave 15, Got 218
Philips make such a system. It's very much entry level, however.
YellowSphere is offline   Reply With Quote
Old 03-05-2008, 3:10 PM   #5 (permalink)
Pincho Paxton's Avatar
Thanks: Gave 32, Got 209
Maybe best to buy small everything, and put the rears on stands sold seperately.
The seating distance thing is quite annoying. Yeah it looks great from 20ft away.. so does my ex!!!. If you can ignore grain, then it's easy to ignore someone that is sending out a lot of noise that you don't like to hear. By the way, I'm being artistic. But maybe you just don't get it.
Pincho Paxton is offline   Reply With Quote
fronts, rears, small, tall
[IMG] code is Off
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Thinking about big fronts with small rears for 1st 5.1 sogden Speakers 2 19-10-2007 9:38 PM
2.1 fronts to 5.1 rears p203557 Speakers 3 15-05-2006 8:30 AM
Rears Tall Stands Dipoles.or what have you.?? abnett26247 Speakers 1 07-01-2005 8:14 AM
KEF Q4 fronts - rears needed - small / silver - WAF victim ppepp Speakers 9 19-03-2004 9:39 AM
Match rears with fronts? jmlane Speakers 3 26-01-2001 5:40 AM
AV ForumsOptimised for Firefox.
