AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 01-05-2008, 1:29 PM   #1 (permalink)
Help: Problem with Samsung SWA-3000 and Wireless Internet connection
Hopefully this is the right place for this post.. I am a newb, so you'll have to forgive me if I mess up my first post!
I recently purchased a Samsung SWA-3000 Wireless Module to go along with my Samsung HT-WX70 Home Theater system. After setting everything up I started to notice my internet connection to my laptop was really struggling. Well after calling Comcast, unplugging everything a few times and then trying to turn off the Home Theater system I have come to find that the SWA-3000 Wireless Module is affecting my Wireless router. When my Home Theater is off my connection is strong and I have no issues. When the Home Theater is on my connection bounces all over the place.
Has anyone experienced this or know of a possible solution? I have a simple Linksys Wireless Router plugged into my Comcast modem. Everything is in the same room, SWA-3000 is on an opposite wall, but the Home Theater and Linksys Wireless Router are fairly close (3 feet).
Thanks for any help!
Jason
thebigsadler is offline   Reply With Quote
Old 02-05-2008, 9:42 AM   #2 (permalink)
RottenFox's Avatar
Thanks: Gave 177, Got 1,036
Re: Help: Problem with Samsung SWA-3000 and Wireless Internet connection
thats the problem with the router you have,and the wireless module,they both work on the same frequency,so are open to interference.
not much can be done about it,i would think,bar swapping the SWA-3000 for a 4000 model,which operates at a higher frequency.
XBL/PSN Gamertag - RottenFoxBreath Wii Code - 5320 0184 6511 5759
- The views i express are my own,and in no way represent the views of AVForums or affiliates -
RottenFox is online now   Reply With Quote
Old 02-05-2008, 4:04 PM   #3 (permalink)
I would think it would be cheaper to buy a new wireless router wouldn't it? Does anyone around here swap the 3000 unit for the 4000?
SWA-3000 is a 2.4GHz and SWA-4000 is a 5.8GHz?
Old 02-05-2008, 7:24 PM   #4 (permalink)
RottenFox's Avatar
cant you return it to the retailer?
i assume that the problem with exist with any 2.4ghz router you buy,so it will be you who has to stump up the cash to buy one that operates on a higher frequency.
i would say ditch the wireless rears,as they are still prone to interference,and can exhude a "hiss" as they are always on,even when not working,like on mute,unlike when wired,and mostly silent.
Old 02-05-2008, 7:30 PM   #5 (permalink)
I don't have any issues with hissing and I know the quality of sound isn't the best. Unfortunately this is the system that best fits the room and budget. I would love to ditch it all and do something much cleaner, but that is for my next house...
I e-mailed the vendor to ask what their return policy was and if there was a possible exchange to be had. We will see what they say.
Thanks for the info.
Old 03-05-2008, 2:23 PM   #6 (permalink)
RottenFox's Avatar
ok,cool,but i never meant ditch the system,just the "wireless" part,if you like the system.
Old 08-05-2008, 4:47 PM   #7 (permalink)
SWA-4000 arrived today and things seem to be going much smoother!
Now just have to sell this SWA-3000 which is brand new but without box...
Old 23-05-2008, 1:45 PM   #8 (permalink)
Thanks: Gave 1, Got 0
What is the SWA-4000 like (performance etc) as I am looking to get the wireless setup along with a HT-TX35R very soon.
I see the 4000 is priced lower than the retail on the 3000 and looks much sleeker.
I just wondered how the box performs in comparison to the 3000 to gauge which one to go for?
Your comments are very much appreciated.
aasgmhill is offline   Reply With Quote
Old 23-05-2008, 4:03 PM   #9 (permalink)
The look of the two didn't matter to me because the unit is hidden behind my couch and no one sees it. The 3000 unit is a bit sleeker if that matters to you.
They both perform equally, but if you have a wireless network in your house the 4000 unit is an absolute must. There is no way I could be listening to something in surround sound while making this post (with the 3000 unit).
Old 27-05-2008, 11:42 AM   #10 (permalink)
The 4000 it is then...soon
connection, internet, problem, samsung, swa3000, wireless
[IMG] code is Off
Refbacks are On
Thread Thread Starter Forum Replies Last Post
PS3 wireless internet connection lovegadgets PS3 7 22-10-2007 1:08 PM
HDE1 and wireless internet connection kerby1991 HD DVD Players 5 03-08-2007 7:21 AM
Samsung SWA 3000 Wireless Kit SweetC Integrated AV Amplifiers and Receivers 2 14-02-2007 7:34 PM
Connecting to the internet via a wireless connection pmerryman Networking 13 26-01-2007 6:36 AM
I want a wireless internet and 360 connection what do I need? crazzy kopite PC Games 6 05-10-2005 2:29 PM
AV ForumsOptimised for Firefox.
