30-04-2008, 11:49 AM
#1 (permalink)
Thanks: Gave 12, Got 23
Help me find a 5.1 tallboy system PLS
Hey all,
Im in the market for a 5.1 all in one home cinema with all round tall boys. I need it in black, 1080p upscaler, 1000watt if poss and optical in.
I know about the Samsung TX35 and the Panasonic PT850 but I cant find these forsale anywhere no more
Looked on the net for the last few days but struggling, I know samsung are bringing out new systems but even them are hard to find.
Please can somebody help, I live near manchester if anybody knows any shops that these systems in stock.
thanks for any help
a
PSN ~ kingcr33ch
COD4 | COD:WaW ~ BFaM
30-04-2008, 12:07 PM
#2 (permalink)
Re: Help me find a 5.1 tallboy system PLS
After I posted the above I managed to track both systems down, but im not sure which to go for? Yesterday I couldn't find any
The samsung can have sync issues but the panasonic is £80 dearer. Not sure which to go for?
Also seen the new samsung HTTZ315, which looks like the update to the TX35, just cant find any reviews. Started a thread on this model trying to get more info but not got a reply yet.
a
PSN ~ kingcr33ch
30-04-2008, 12:49 PM
#3 (permalink)
Thanks: Gave 4, Got 946
Just forget 1000+ watts, there is no chance of any all-in-one reaching that power output, you are talking disco level in a large hall. Look at a disco amp it's built into a a huge 19" rack mount case any weigths a ton.
Just look at the power consumption (100-200watts then take away power losses + other power drains and you are not left alot) which will give a better clue to its real output.
As one reviewer stated whilst reviewing some quality AV kit, "Why do manufacterers hyperinflate there output levels with their all-in-ones".
I wish they would give sustained output power continuously ALL Channels driven that would then take away any confusion.
30-04-2008, 3:14 PM
#4 (permalink)
Cheers bud, will take that on board. Anychance of recommending me a system?
Its really hard trying to pick one from the spec
a
PSN ~ kingcr33ch
30-04-2008, 4:47 PM
#5 (permalink)
Mate i just bought a 850.
After some inital problems setting it up, its quality.
Have my ps3 hooked up and the sound is fantastic.
I would recommend this to anyone.
The speakers look sweet, i have attached the front ones to the wall either side of the tv, the rears are still on the stands.
All in all it looks good, sounds good.
Hagle on the price and you might get a better deal,
30-04-2008, 5:29 PM
#6 (permalink)
Thanks: Gave 53, Got 176
The Panny 860 is out now, apparently with improved upscaling (one of the gripes mentioned in the 850's thread) and a few other improvements, go for that above the 850.
Oh and check this LG out, the LG HT903TA. It's the successor of the acclaimed and highly revered 902TB ('What Hi-Fi' 5 star winner), and my gosh 'tis a thing of beauty. You've gotta give it to LG design wise...
http://uk.lge.com/products/model/det...ht903ta.jhtml#
Samsung LE32R72B LCD
Sony HT-SF1200 Amp
Sony RDRHX870 DVD HDD
Tacima CS929 & PS3.
01-05-2008, 7:53 AM
#7 (permalink)
Thanks for the help guys, wow the LG systems do look good
This is going to be a present for my girlfriends dad so I don't think they'll want to pay over 250ish. The pana and LG are probably abit over budget
Think I might try the samy HTTZ315, it seems to fit the spec needed and can be had for about 270 with next day del. Hopefully they would have sorted the sync problems from its older bro, the TX35.
If anybody knows of any more systems I can get for arond the same price please post away, will probably be ordering this wkend.
a
PSN ~ kingcr33ch
01-05-2008, 11:56 AM
#8 (permalink)
Well i've ordered the samy HTTZ315 and it comes tomorrow.
Its for my girlfriends dad but i'll be setting it up while he is away.
Will let you know how it goes
Thanks for the help
a
PSN ~ kingcr33ch
01-05-2008, 12:03 PM
#9 (permalink)
Thanks for the help
Nice, I'm sure more than one person on this forum will be wondering if this model fixes darn those lip sync issues, surely it does...
Sony HT-SF1200 Amp
Tacima CS929 & PS3.
16-05-2008, 8:58 PM
#10 (permalink)
Thanks: Gave 30, Got 38
So any good?
Thanks for the help
23-06-2008, 9:14 PM
#11 (permalink)
Thanks: Gave 2, Got 1
I'm very impressed with HT-TZ315. Sounds are crisp & loud. I haven't had any syncing issue yet.
