30-04-2008, 10:01 AM
#1 (permalink)
Thanks: Gave 4, Got 1
all in one with Optical Audio input for £150
Am just about to buy a Panny 42PX80 plasma and want to get a dvd cinema setup to go with it. I would like to be able to play Tv through the surround system and would appreciate any recommendations on all-in-one solutions which offer Optical Audio input (im pretty sure the PX80 has optical audio out).
I dont want to spend too much and to be honest am no expert when it comes to sound quality so just looking for something about £150 which will allow good sound from DVD and my freeview playing through the 42PX80
Any recommendations greatly received.
Chris
30-04-2008, 10:09 AM
#2 (permalink)
Re: all in one with Optical Audio input for £150
oops should have said not bothered about 5.1 surround
thanks
chris
Reason: incorrect
30-04-2008, 10:10 AM
#3 (permalink)
Thanks: Gave 13, Got 41
Originally Posted by mcdermott_c
Chris
How about £180? That would get you a Sony HT-SS1100, if you can find one. Other than that I'm not sure if there's anything for £150 presuming you want 5.1 surround. Could try second hand.
AV - TH-37PX70, HD-EP10 MR, HD-EP30, PS3, V+, HT-SS1300 HI-FI - IIXE900, RB300, Corus Black, RA-01, C521BEE, CR-2E, iPod 30GB, DB6, Diamond 9.1 & Coda 7's PLAY - PS3 250GB
I'm a Mac.
30-04-2008, 10:13 AM
#4 (permalink)
Hi Stefnar
Not too bothered about full 5.1 surround - just looking for good sound really do you have any other recommendations
cheers
chris
30-04-2008, 10:25 AM
#5 (permalink)
Hi Stefnar
cheers
chris
TBH not for that price, although someone may know of others. Have you got a stereo amplifier? if you have, why not connect to your tv with phono cables that at least would give you boosted 2.1 sound.
I'm a Mac.
30-04-2008, 10:43 AM
#6 (permalink)
no i dont have a stereo amplifier. I do however have a Wharfedale LP160DTR freeview recorder which on the back has a connector that says optical out. Would this be digital output from the freeview and if so could i use this to plug directly into the all in one system ?
cheers
02-05-2008, 1:24 PM
#7 (permalink)
Thanks: Gave 2, Got 3
02-05-2008, 3:37 PM
#8 (permalink)
Thanks: Gave 32, Got 209
I can't find an optical output from this TV and you don't need one. You usually go from DVD Player to Amp, or Skybox to Amp, Freeview to amp. The TV will probably output sound in Stereo anyway, so all you need for £150 is a hifi.
The seating distance thing is quite annoying. Yeah it looks great from 20ft away.. so does my ex!!!.  If you can ignore grain, then it's easy to ignore someone that is sending out a lot of noise that you don't like to hear. By the way, I'm being artistic. But maybe you just don't get it.
05-05-2008, 8:56 PM
#9 (permalink)
thanks guys
Bought a Samsung HT Z310 which has hd upscaling and optical in so should do the trick if i can get the settings correct. Im just using scart at the moment and the PQ watching a DVD on my 42PX80 is rubbish. I will try an hdmi cable to see if it improves PQ if not i'll need to get back on here for more advice. After advice from on here im really impressed with freeview PQ on the panny !
cheers
chris
