AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 29-04-2008, 10:12 PM   #1 (permalink)
Can't get sound from TV through home cinema
I have a 40" Samsung HD TV, Xbox360 and bought a 5:1 DVD home cinema system today.
The 360 is connected to the TV via HDMI cable and works fine.
The cinema system works fine when you insert CD's into the player but can't seem to get any audio from the TV/XBOX. I am connecting to the TV from the system by another HDMI cable.
Driving me mad spent 3 hours doing this!
Cheers, Olly
Ogginz is offline
Old 29-04-2008, 10:50 PM   #2 (permalink)
berkeley384's Avatar
Thanks: Gave 23, Got 48
Re: Can't get sound from TV through home cinema
Hello Olly,
Think you should have posted this in the all in ones section,however ...
You say you have a HDMI cable going from the XBOX to the TV, which is fine, this should make the sound come out of the TV ...
But l dont understand what you mean by ...
It sounds like what your saying is that you've connected another HDMI lead into the back of the TV and into the Cinema system and expecting to get sound.
If this is the case, the HDMI connections on your TV are inputs, you cant output sound from them. There is normally either a pair of red and white phono style outputs or sometimes an optical out.
What DVD cinema system do you have, this may make it easier to understand what connections you have available to you
Stephen
berkeley384 is offline
Old 29-04-2008, 10:52 PM   #3 (permalink)
Thanks: Gave 1, Got 11
Dont hold me to it as i dont own a HDMI amp but i would assume you have to feed back to the amp with either Optical or coaxial rather than use a HDMI cable
scott R is offline
Old 29-04-2008, 11:03 PM   #4 (permalink)
Originally Posted by berkeley384 View Post
Hello Olly,
Stephen
Yes.. I feel stupid now, I didn't know that it was only 1 way!
I have the 'Samsung HT-Z310'.
With the system I got a single cable with yellow ends. (Sorry I am useless with this stuff, hence why I'm here!)
I have an old scart lead which I have tried but still no luck.
Thankyou for the feedback so far.
Olly
Ogginz is offline
Old 29-04-2008, 11:16 PM   #5 (permalink)
The yellow lead I presume is for video - Im guessing its a single phono style lead
I cant find the manual for your system, but Im guessing at that price, it will have red and white aux inputs for audio from a secondary device, such as your Xbox /TV etc
This is all hyperthetical as I dont have all the info but my guess is that you will need to do the following
Connect your XBOX to your TV Via HDMI input 1
Connect your DVD/Home Cinema to your TV via HDMI input 2
Look on the back of your TV for the Red and white audio outputs (be sure you get the outputs because its likely you'll see red and white inputs too). Connect a pair of Red and white phone leads from the TV to the DVD Home cinema's red and white inputs.
You will probably have to select AUX on the DVD Home cinema system, and this should hopefull provide you with sound ... he says optimistically
Old 30-04-2008, 6:16 AM   #6 (permalink)
Yep have all those connections
Thanks for the help, will get the leads at lunch time and give it a try tonight.
Will report back if it works.
Cheers!!
Olly
Ogginz is offline
Old 30-04-2008, 9:34 AM   #7 (permalink)
albriscoe's Avatar
Thanks: Gave 304, Got 264
Cheers!!
Olly
and if it doesn`t how long should we wait before reporting you missing and contacting the local A & E.
Click to see my selfbuild/basement cinema
Onkyo TX-NR 905 M&K`s SW150 fronts SW95s rears Sub M&K MX125 Mk 11 SIM Grand Theatre PJ 118" 16.9 fixed screen HTPC Asus AMD2 6000+ CPU LG BD/HD player 4gb DDR2 Ram 5t/b h/drives Panny TH-50PX70 / TH-42PX70 Samsung LE40A756/BD-P 1500 Humax Freesat HD
albriscoe is offline
Old 30-04-2008, 10:53 AM   #8 (permalink)
inzaman's Avatar
Thanks: Gave 60, Got 232
Moved to all in ones
Visit my Home Cinema here
inzaman is offline
Old 02-05-2008, 11:22 AM   #9 (permalink)
Thanks: Gave 17, Got 14
I believe this is a new model, replaces HT-X30R, and has similar connections - so I think you have the option of optical or phono leads.
IanSimmons is offline
Old 02-05-2008, 6:41 PM   #10 (permalink)
It worked!
I used the phonos from an old scart cable. Aux2.
Thanks for the help guys, appreciate it.
Phonos or optical? Any difference in quality?
So far it seems I've wasted £35 on the HDMI cable.......
Wonder if its better to use with my 360 then the normal £13 360 HDMI cable? Hmmm...
Ogginz is offline
Old 02-05-2008, 7:27 PM   #11 (permalink)
RottenFox's Avatar
Thanks: Gave 161, Got 942
phono vs optical,for stereo audio...no difference really.
and £35 for an hdmi cable..cant you return it,as there will be no difference with the £13 to that one.
XBL/PSN Gamertag - RottenFoxBreath Wii Code - 5320 0184 6511 5759
- The views i express are my own,and in no way represent the views of AVForums or affiliates -
RottenFox is offline
Old 15-05-2008, 10:17 PM   #12 (permalink)
Thanks: Gave 1, Got 0
The unit u have DOES support optical in. This will allow the you to send DOLBY DIGITAL sound from skyHD/sky+ or PS3 or Bluray player using a TOSLINK optical cable. You can get these for under a fiver from ebay (or pay £20 to maplin for the exact same thing!!)... (If u want to connect 2 sources eg. skyHD & ps3 you need an optical switcher as the unit only has 1 optical input)
However, if you are only going to be sending stereo signals to the home cinema system then it shouldnt make a difference whether you use optical or phono.
thedonis is offline
cinema, home, sound
[IMG] code is Off
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Problems getting TV sound through LG home Cinema - 37LC46 TV and HT552TH home cinema zap48uk Interconnects, Speaker Cables and Switches 11 08-05-2008 8:56 AM
No sound through Home Cinema ? simon109 Interconnects, Speaker Cables and Switches 4 10-01-2008 8:18 PM
Home Cinema 5.1 Sub Currently 80w - will 120 w sound better? Paul Cooksley All-in-one Systems 5 01-02-2006 7:51 AM
Home Cinema Set Up - No Sound !! pgraham Home Cinema DIY 2 13-10-2005 12:50 PM
Home Cinema Sound Help milanlad Audio Processors and Power Amps 5 04-10-2004 11:39 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
