AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 29-04-2008, 3:27 PM   #1 (permalink)
Thanks: Gave 12, Got 8
Panasonic SC-PT850 / SC-PT860 connections.
Im considering getting one of these as it seems to fit my needs - 5.1 speakers that will match TV, and amplifier.
My question is, I am going to build a HTPC and everything going onto the screen would come from this, but im not sure how you would connect this up ? (Bearing in mind no mobo yet does sound through hdmi, so I would need to use optical cable or something as I would like to have surround sound if available)
Would it go :
HTPC (HDMI) > TV
HTPC (Optical) > SC-PT8?0
or if sound was to go through the hdmi (in future when mobo's support this), would it go :
HTPC > (hdmi) > SC-PT8?0 > (hdmi) > TV
Could anyone clear this up for me, as im not sure what connections are available on the SC-PT8?0 units.
Thanks!!!
Jim_b0b is offline   Reply With Quote
Old 29-04-2008, 4:48 PM   #2 (permalink)
Re: Panasonic SC-PT850 / SC-PT860 connections.
On the back of the 850 YOU have an audio in connection.
On the back of the tv you will have an audio out,
Simply connect the av cables to these sockets, anything that goes through your tv will be surround sound.
ukfirefight is offline   Reply With Quote
Old 29-04-2008, 10:25 PM   #3 (permalink)
So, are these rca connections on the PT8?0, not hdmi ?
and the cables would go
htpc > (hdmi) > TV > (rca/hdmi) > PCT8?0
Thanks for your help by the way.
Old 29-04-2008, 10:54 PM   #4 (permalink)
kentish_lad's Avatar
Thanks: Gave 25, Got 205
You would connect as you first said
Would it go :
HTPC (HDMI) > TV
kentish_lad is online now   Reply With Quote
Old 29-04-2008, 11:30 PM   #5 (permalink)
Ahh thanks very much!
Just thinking ahead, but if I get a mobo in the future that supports audio over hdmi then is ther anyway to go though the PT8?0, ie.
HTPC > (hdmi) > PT8?0 > (hdmi) > tv
or does the PT8?0 only accept an audio / optical input ?, and where can I find what audio formats it supports, ie. Dolby Digital, True HD etc...
Sorry for all the questions guys, just want ot weigh up my options.
Old 30-04-2008, 8:06 AM   #6 (permalink)
Well the back of my 850 has
1 hdmi
1 scart
1 aux in
1 optical audio
and three other outputs that i'm not quite sure what they are, but i asume they are for those people that want to use audio and video leads in stead of hdmi or scart.
I think its called progressive scan. ???
Old 30-04-2008, 11:05 AM   #7 (permalink)
Thanks: Gave 92, Got 83
no only optical m8
GIGABYTE P35-DS3R-8Gb OCZ Gold
WOLFDALE E8500@4.0GHZ-
EVGA GTX260@750/1250/1500-500GB-AAKS
CORSAIRHX520-ANTEC-300-CASE-VISTA 64BIT
sunderland is offline   Reply With Quote
Old 30-04-2008, 11:42 AM   #8 (permalink)
kingcr33ch's Avatar
Thanks: Gave 12, Got 23
Anybody know where these are still forsale?
Im having trouble finding any on the net
a
PSN ~ kingcr33ch
COD4 | COD:WaW ~ BFaM
kingcr33ch is offline   Reply With Quote
Old 30-04-2008, 1:23 PM   #9 (permalink)
Yes, me too, I think the SC-PT850 has been superceeded by the 860, but I read that the 860 is not as good ? (Uses a different sub, and different speaker connections that only allow for the supplied speakers)
Old 30-04-2008, 3:06 PM   #10 (permalink)
kingcr33ch's Avatar
Found this place bud, not sure if Martin dawes are any good like
http://www.martindawes.net/ProductDe...language=en-GB
a
PSN ~ kingcr33ch
Old 30-04-2008, 6:24 PM   #11 (permalink)
Has only 1 HDMI output, only supports DD via optical
Old 30-04-2008, 6:30 PM   #12 (permalink)
Availability: Out of stock
connections, panasonic, scpt850, scpt860
[IMG] code is Off
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Panasonic SC-PT850, still available ? Jim_b0b All-in-one Systems 1 27-04-2008 9:21 PM
Panasonic SC-PT850 vs SC-PT860 Mattjc All-in-one Systems 6 23-04-2008 1:00 PM
Panasonic SC-PT860 EBK? ctucker99 All-in-one Systems 3 25-02-2008 8:51 PM
Panasonic SC-PT850 ianeverton All-in-one Systems 4 06-02-2008 3:29 PM
Panasonic SC-PT850 SavXtreme All-in-one Systems 2 13-01-2008 7:22 PM
AV ForumsOptimised for Firefox.
