AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 13-02-2008, 1:59 PM   #1 (permalink)
Philips HTS3357 - Xbox 360 surround sound
Hi i have just bought A Philips HTS3357 ( http://www.amazon.co.uk/Philips-HTS3.../dp/B000RT88P8)
My question is will i get 5.1 surround sound purely from the xbox-tv HDMI connection playing through the DVD player, or do i need to connect direct (in which case presumably i need an optical-digital audio converter - any thoughts?).
layers is offline   Reply With Quote
Old 13-02-2008, 4:37 PM   #2 (permalink)
RottenFox's Avatar
Thanks: Gave 177, Got 1,036
Re: Philips HTS3357 - Xbox 360 surround sound
no,you wont get audio through hdmi with that system..
what xbox 360 is it you have?
if its the premium,you will have to buy the hdmi lead/audio dongle pack,as the xbox doesnt allow hdmi,and component/vga leads to be used at the same time,so you cant use the optical out,on those leads.
the hdmi lead/dongle pack,contains,an hdmi lead,and what looks like the stub of a component/vga cable,but only has analogue and digital audio outputs on it,and retails at about £30.
this will allow you to use hdmi video,and have optical audio for 5.1.
you could butcher a cheap vga/component cable,removing the case,so that the hdmi lead,and the newly made "dongle" can be used together.
if you have an elite,all you do is plug the dongle in(the elite comes with one in the box),and the hdmi lead into the tv directly,then plug an optical lead,into the philips surround.
if the philips surround doesnt have optical audio in,then yes,you would need an optical - coax convertor,but thats only if the philips has coax audio in.
personally,if it doesnt have those inputs,send it back,and use the little extra you would spend on a convertor,to buy a system that has an optical audio in.
XBL/PSN Gamertag - RottenFoxBreath Wii Code - 5320 0184 6511 5759
- The views i express are my own,and in no way represent the views of AVForums or affiliates -
RottenFox is offline   Reply With Quote
Old 13-02-2008, 4:57 PM   #3 (permalink)
Thanks for the reply. Fortunately it's an elite so i guess i need to convert my optical signal from my dongle to digital for the DVD player - will check prices and decide what to do then.
Thanks again
Al
Old 06-03-2008, 11:15 AM   #4 (permalink)
Thanks: Gave 5, Got 0
hi, i just wondered if you could answer this question for me about this system. I have ordered one, (for £69 thought it was a bargain) and just wanted to know if it is possible to have the tall boy speakers at the front?
Are the speakers hard wired into the system or can the wires be extended etc? How long would you say the cables are for each speaker. I only have a small living room but dont think the wire for the front speakers will be long enough to reach the back of my room?
sdjpaterson is offline   Reply With Quote
Old 06-03-2008, 12:27 PM   #5 (permalink)
Hi - £69 seems to be a very good price - can you tell me where you purchased it from? Thanks
paddy512 is offline   Reply With Quote
Old 06-03-2008, 5:09 PM   #6 (permalink)
Dubster's Avatar
Thanks: Gave 19, Got 40
They are hardwired into the back of the speakers and the front speaker wires are not overly long so like me youll probably have to extend them (solder for best possible connection)
Dubster is offline   Reply With Quote
Old 11-04-2008, 11:41 PM   #7 (permalink)
Where can this dongle be purchased? and what does it look like, I have the elite but dont seem to have anything like you have described.
cheers
doublej41 is offline   Reply With Quote
Old 12-04-2008, 2:09 PM   #8 (permalink)
RottenFox's Avatar
cheers
http://images.google.co.uk/images?q=...=1&sa=N&tab=wi
top left hand picture.
it comes in the box with the elite,and the hdmi cable.
if you have an elite and never got one,then phone up microsoft,and complain.
360, hts3357, philips, sound, surround, xbox
[IMG] code is Off
Refbacks are On
Thread Thread Starter Forum Replies Last Post
How to get surround sound from philips hts3357 to xbox 360? Cyclone27 Xbox 360 14 13-11-2007 4:22 PM
Will these cables work With my Xbox 360 And HDTV To My Philips Hts3357? Cyclone27 Xbox 360 11 23-09-2007 6:21 PM
On The Philips HTS3357 will the surround sound be on all the time for the TV?? Cyclone27 All-in-one Systems 8 18-09-2007 8:03 PM
How Do You Connect the PHILIPS HTS3357 to An Xbox 360?... Cyclone27 All-in-one Systems 3 10-09-2007 10:12 AM
Will Surround Sound From PHILIPS HTS3357 work on an Xbox 360?? Cyclone27 All-in-one Systems 1 04-09-2007 7:26 PM
AV ForumsOptimised for Firefox.
