AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 12-02-2008, 10:11 PM   #1 (permalink)
Annoying Audio Problem
hi guys,
My setup is:
Jamo's DMR61 (5.1 surround system with built in dvd player and hdmi out)
50in Samsung Plasma
Sky +
PS3
Another satellite
When watching a dvd through jamo, or sky or other satelite, the sound is fine, but the ps3 bluray is causing massive problems.
Im forver turing the volume up and down (up for vocals, down for action scenes), and the bass through ps3 is SO high.
I have tried enabling the dynamic range control in the ps3 settings but still the same.
I have ps3 hooked up via digital optical out.
I also have a setting on the receiever for dynamic range control, but i think thats only if im watching a dvd through the receiver
any ideas please guys?
newcomers is offline   Reply With Quote
Old 12-02-2008, 10:20 PM   #2 (permalink)
kentish_lad's Avatar
Thanks: Gave 25, Got 205
Re: Annoying Audio Problem
Originally Posted by newcomers View Post
hi guys,
My setup is:
50in Samsung Plasma
Sky +
PS3
Another satellite
Not normally, DRC on the jamo should work on all sources
kentish_lad is online now   Reply With Quote
Old 12-02-2008, 10:25 PM   #3 (permalink)
Well ive tried all the settings in DRC and it makes no difference at all
Its so annoying having to adjust the volume the whole time through a movie
Old 12-02-2008, 10:38 PM   #4 (permalink)
Is the PS3 sound menu for Octical out set to Dolby Digital ??
The DRC on the Jamo only works on a DD source (According to manual)
Old 12-02-2008, 10:39 PM   #5 (permalink)
Yeah it is mate
where in the manual does it say that?
Old 12-02-2008, 10:58 PM   #6 (permalink)
Yeah it is mate
On Page 11 mate
Old 12-02-2008, 11:09 PM   #7 (permalink)
On Page 11 mate
well actually the input mode on the receiver says pro logic, cos its conneced via digital optical, so I dont think that counts as DD, even though the audio on the bluray is set to dolby digital
Old 12-02-2008, 11:19 PM   #8 (permalink)
Theres your problem, so you are not getting true 5.1 via the PS3
The Jamo should be flagging up Dolby Digital then you can set up the DRC
I would have a play with the audio output on the PS3
Set to 'BITSTREAM'
Old 13-02-2008, 6:57 PM   #9 (permalink)
Set to 'BITSTREAM'
just checked and it does say dolby digital, but I have the audio setup to pro logic (other options are, movie, stereo, but with these settings there is no surround sound)
ALso, just remembered that setting the DRC on the ps3 whilst watching Casino Royale worked, but it hasnt on ratatouille. I wonder if it has anyting to do with the audio formats on the discs?
Old 18-03-2008, 2:45 PM   #10 (permalink)
harmeetsingh's Avatar
Hi there- did you manage to resolve this? I'm expereincing a similar problem! Cheers.
harmeetsingh is offline   Reply With Quote
Old 18-03-2008, 6:26 PM   #11 (permalink)
no mate, still the same
hoping the new ps3 update might sort it but im not too hopeful
Old 18-03-2008, 9:48 PM   #12 (permalink)
That's what I'm hoping too mate - any rumours on any dates? oh well will have to revert to the player in the meantime.
Old 19-03-2008, 1:46 AM   #13 (permalink)
downloaded and installed it yesterday but havent had a chance to test it
whats the problem with yours anyway?
Old 19-03-2008, 12:40 PM   #14 (permalink)
Similar problem to yours mate - the vocals just get drowned out - the update didn't seem to have any affect. Was more for stability issues.
Old 19-03-2008, 5:38 PM   #15 (permalink)
what receiver do you have?
Im thinking of maybe buying a better one that wont have this problem. Shame really cos I only got this one in the summer and paid £500 for it!!
Its so annoying though
annoying, audio, problem
[IMG] code is Off
Refbacks are On
Thread Thread Starter Forum Replies Last Post
An annoying problem godzilla1 Speakers 7 23-10-2007 11:59 AM
Annoying Sky+ problem savlad Sky and Sky+ 2 25-10-2006 7:41 PM
problem, really annoying AnDyR0o Satellite TV 8 13-07-2006 4:33 PM
Zero 7 - Simple Things - annoying audio dropout Squirrel God Music 11 21-01-2003 3:31 PM
Annoying Sky+ RGB problem boltoa Sky and Sky+ 13 18-12-2002 11:13 AM
AV ForumsOptimised for Firefox.
