12-02-2008, 11:46 AM
#1 (permalink)
Thanks: Gave 52, Got 5
Help my folks get Cinema Sound
Firstly, appologies if this is in the wrong place, i'm sure a mod will move it if it is.
Secondly, my problem.
My Parents recently witnessed my surround sound setup and have decided that they would like something better than they currently have. However its a tricky one.
Their budget is £200 ( i can probably notch it up to £250)
They currently have a Sony CRT Widescreen TV.
Sky Plus and a Sony DVD Recorder (Sorry no model numbers at present)
It will probably be a while before the tv is upgraded so i dont think HDMI is a primary concern at the moment.
They'll need something that is easy, they will want a system that gives them the minimum hassle (ie they'd like to turn it on and it just works!)
So, in conclusion, i guess for the budget were looking at an all in one comet/currys type system. But i wonder if any of you guys could help with some sugestions of good kit for this budget?
Kicking Squealing Gucci littel piggy
12-02-2008, 12:04 PM
#2 (permalink)
Thanks: Gave 118, Got 924
Re: Help my folks get Cinema Sound
If they like Sony, have a look at the HT-SF1100 (amp/speakers). It's at the top end(ish) of your budget and doesn't come with a DVD, which they don't need. It has 2 optical and 1 digicoax in, which is the minimum you should look for. The Sony all-in-ones don't sound too bad. I would always recommend going for separates but you would need to up the budget.
AV Setup Panasonic TH42PZ81 | Hitachi PJTX200 | Toshiba HD-EP35 | Pioneer DVR540HX-S | SB3 | Xbox360&PS3 | Sky HD & FreeSat | Denon AVR3805 | Arcam Alpha7&8 | Tannoy Mercury | SVS PB1-ISD | Harmony One |
12-02-2008, 12:29 PM
#3 (permalink)
Thanks: Gave 177, Got 1,036
ill move this to the All-in-Ones forum.
its more suited there.
XBL/PSN Gamertag - RottenFoxBreath Wii Code - 5320 0184 6511 5759
- The views i express are my own,and in no way represent the views of AVForums or affiliates -
12-02-2008, 12:31 PM
#4 (permalink)
Thanks: Gave 52, Got 25
Just a suggestion that fits your budget....
Yamaha RXV361 (£119.95 from Richer Sounds) 2 optical/1 coax
Yamaha NSP110 5.1 speaker package (£79.95 from RS again / £69.95 from Empire Direct)
12-02-2008, 12:43 PM
#5 (permalink)
I'd considered this, my parents aren't really technically minded would they cope with it, i guess they just want to be able to switch on the tv and have the sound there alreadt, ideally i dont want to burden them with remote controls.
12-02-2008, 12:51 PM
#6 (permalink)
Thanks: Gave 25, Got 205
A bit over the top for what your Parents can handle id imagine, what about one of the cheaper sony ones easy to use and possibly use one remote
12-02-2008, 12:53 PM
#7 (permalink)
it hadn't occured to me that with all the sony stuff they could probably merge the remotes.... next thing... ideally needs to be silver
12-02-2008, 1:01 PM
#8 (permalink)
Something like this??
http://www.sony.co.uk/view/ShowProdu...%26+DVD+Player
12-02-2008, 1:05 PM
#9 (permalink)
perfect, reckon thats as good as they'll get on the money, i'll have to convince my mum that the speakers need to be positioned correctly!!
Cheers for the help
12-02-2008, 1:09 PM
#10 (permalink)
Cheers for the help
I dont know how old they are, they probally just need a no nonsence, easy to use system that gives them a nicer sound then their TV does at present
12-02-2008, 1:23 PM
#11 (permalink)
Mid Fifties, the Tv has surround to a point, 5 speakers (no sub) but its not great.
12-02-2008, 2:33 PM
#12 (permalink)
OH  i thought they were elderly
12-02-2008, 2:34 PM
#13 (permalink)
some might say they are !!
