AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 11-02-2008, 10:01 PM   #1 (permalink)
Sony DAV-IS10 rear speaker cable
I've just purchased a Samsung LE40M86BD TV to replace my dying 12yr old 32 inch CRT TV and a Sony DAV-IS10 Home cinema.
These are being delivered next week, currently I have a Sony DAVS-550, its been a really good home cinema for 5 years, but now I want the HDMI and upscaling DVD.
I fitted the rear speak cables under my wooden floor when it was installed 2 years, so i was wondering if the rear speaker cable on the DAVS-550 is the same as on my new Sony DAV-IS10, as this would be ideal as I do not need to mess around changing cables, anyone know if the cables are universal between the 2 systems? if not, whats the best way fit the DAV-IS10 to the DAVS-550 cables under the floor? I'd rather not have to thread the rear speaker cable around the room and lifting the floor is not an option.
Thanks for any advice.
ecnirp is offline
Old 11-02-2008, 10:05 PM   #2 (permalink)
kentish_lad's Avatar
Thanks: Gave 25, Got 192
Re: Sony DAV-IS10 rear speaker cable
Originally Posted by ecnirp View Post
You can keep the cables but remember they dont connect to the amp like the 550, they connect to the SUB on the IS10 so you might be a bit short on the lengths
kentish_lad is offline
Old 11-02-2008, 10:09 PM   #3 (permalink)
No offence mate but its better to stick to 1 thread for you questions as its gets a bit confusing overwise
Old 11-02-2008, 10:17 PM   #4 (permalink)
np, didn't think it was really related that much to the first thread.
I'm intending to put the sub where the old CRT TV is as it was a in bay window, thats a big sub ! so the rear speaker cable should reach, I know the speaker end of the cable is the 2 prong cable, the DAVS-550 end is the coloured Sony connectors, are these the same connectors that are used on the IS10 then ?
ecnirp is offline
Old 11-02-2008, 10:29 PM   #5 (permalink)
They still use the colour coded connectors, dont know if they are the same but the IS10's connectors can be removed from the cable, so you could fit these to your existing cables
Old 11-02-2008, 11:57 PM   #6 (permalink)
Cool, thanks for the info.
ecnirp is offline
cable, davis10, rear, sony, speaker
[IMG] code is Off
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Sony DAV-IS10 speaker cable question simon_murray03 All-in-one Systems 10 31-03-2008 2:39 PM
Rear speaker cable too short... RICK67 Interconnects, Speaker Cables and Switches 1 31-12-2007 10:35 AM
Rear Speaker Cable..... HCK Interconnects, Speaker Cables and Switches 4 14-10-2005 6:42 AM
cheap rear speaker cable? garyc Interconnects, Speaker Cables and Switches 1 21-07-2005 1:12 PM
Which Rear speaker cable? silentbob Speakers 11 17-07-2003 11:27 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
