AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 11-02-2008, 4:18 PM   #1 (permalink)
Thanks: Gave 1, Got 0
Would a 5.1 System improve the sound quality of my Samsung TV.
My understanding is that 5.1 sound interprets Dolby encoding which DVDs employ.
On the other hand, in Europe (unlike the US) broadcast digital TV uses MPEG3 for audio compression (also MPEG3 for video) and not the Dolby system (which produces separate 'strands' for each speaker).
Does the MPEG3 signal produce equivalent 5.1 results?
I ask this because I have a Samsung LE40M8 (beautiful picture) and am thinking of linking a Samsung HTX30R 5.1 package to improve the sound quality. Would there be any point in going down this road, given that at this stage at any rate, my interest is directed more to TV than DVDs?
If the answer is 'Yes', should the cabling between the two be HDMI, audio optical or what for best results?
jackspencer is offline   Reply With Quote
Old 11-02-2008, 4:21 PM   #2 (permalink)
mooperman's Avatar
Thanks: Gave 340, Got 141
Re: Would a 5.1 System improve the sound quality of my Samsung TV.
i would say a definitive YES..... sound is much much better... i couldnt go back to my normal TV sound now. If your using a sky+ or Sky HD box then optical is your best bet as you will get true 5.1 sound, if your just normal sky (like me) or normal TV then a standard L+R audio cable with your 30r set to dolby pro logic 2 is much better.....
Xbox 360 Tag - Original Moo ------- PSN Tag - Original-Moo
mooperman is offline   Reply With Quote
Old 12-02-2008, 12:29 PM   #3 (permalink)
Thanks mooperman.
Would anyone else care to comment, particularly on the theory?
Old 12-02-2008, 12:54 PM   #4 (permalink)
kentish_lad's Avatar
Thanks: Gave 25, Got 205
Originally Posted by jackspencer View Post
Thanks mooperman.
Yes go for it, you TV's own sound will be like an old Transistor Radio compered to a Samsung all-in-one
kentish_lad is offline   Reply With Quote
Old 12-02-2008, 5:05 PM   #5 (permalink)
Thanks: Gave 15, Got 9
Most definitely YES!!!
You cant compare the lcd speakers to a 5.1 surround sound system.
Especially if you have sky hd or some kind of blu ray player.
Also if the program you are watching isnt in dd5.1 you cant use pro logic II and that still sounds a million times better than your tv speakers.
muffins is offline   Reply With Quote
Old 12-02-2008, 5:33 PM   #6 (permalink)
mossym's Avatar
Thanks: Gave 32, Got 158
samsung are one of the worst sounding tv's in the market, partly due to their insistance on having downfiring speakers hidden behing the panel. makes the tv's much tidier looking, but sounds crap. definitetly an improvment if you upgrade
My Home Cinema Room
My Gear: 108" Carada Screen, Panasonic AX100, Denon AVR3808, B&W 6 Series speakers, Panny BD35, HTPC, XBOX 360, WII
mossym is offline   Reply With Quote
Old 13-02-2008, 4:23 PM   #7 (permalink)
RottenFox's Avatar
Thanks: Gave 177, Got 1,036
nothing wrong with the speakers on the F8 series tv.
in fact,the rear facing speakers on the back of the tv,add to the bass,and make it sound more fuller.
XBL/PSN Gamertag - RottenFoxBreath Wii Code - 5320 0184 6511 5759
- The views i express are my own,and in no way represent the views of AVForums or affiliates -
RottenFox is offline   Reply With Quote
improve, quality, samsung, sound, system
[IMG] code is Off
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Improve sound quality on LCD flatscreen TV wineboy LCD Televisions 3 17-08-2007 8:29 AM
What can I do to improve the sound quality in my room? Anthracyte Room Acoustics, Audio and Video Calibration 0 05-06-2006 7:41 PM
Can I improve sound quality of PSP glengates PSP 2 15-02-2006 1:03 AM
How can I improve sound quality. spiderman999 Home Cinema DIY 13 21-12-2005 8:18 AM
How to improve sound quality from HTPC ? Erling Sounds Cards, Mics, Headsets and Computer Speakers 7 19-04-2005 7:13 PM
AV ForumsOptimised for Firefox.
