AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 11-02-2008, 3:21 PM   #1 (permalink)
Thanks: Gave 14, Got 15
Help!! 5.1 / 6.1 All-in-one on a budget.
Just convinced my better half that as part of the Living Room re-decorating, its time to replace the Samsung DVD Home Cinema system with a more-dedicated setup.
I'll have my Tosh HD-EP30 and Sky HD permenantly connected to it, and occasionaly my PS3 - therefore I'll need 2 (poss.3) Optical Ins. HDMI 2/1 switcher or 3/1 switcher would be nice, as it'll mean less cables to the TV
I don't mind wether it's a 5.1 or 6.1 setup, as long as they are satellite speakers that I can wall mount. As the rest of my kit is mainly black, I'd prefer if the receiver was the same (although silver isn't the end of the world).
Tricky part is my budget - I've got about £200 to spend I've been looking at the Sony HT-DDW790 (£169 at Play.com) but it's only got one optical in. The 890 is an option, but the wife isn't overly keen on the look of the speakers !!
Any other suggestions would be greatly appreciated
I'm going to be undertaking a pretty major job on the living room , so will post pictures in the DIY thread once it gets underway
midlandscomics is offline
Old 11-02-2008, 4:06 PM   #2 (permalink)
Thanks: Gave 4, Got 873
Re: Help!! 5.1 / 6.1 All-in-one on a budget.
This will give 2 opticals and one co-ax, http://www.pixmania.co.uk/uk/uk/5420...ema-syste.html
Andy98765 is offline
Old 11-02-2008, 4:23 PM   #3 (permalink)
Thanks, will check it out
Old 11-02-2008, 4:29 PM   #4 (permalink)
Chilly Willy's Avatar
Thanks: Gave 9, Got 78
Lightbulb Re: Help!! 5.1 / 6.1 All-in-one on a budget.
Hi mate,
This optical switch:
http://www.kenable.co.uk/product_inf...243928c10bd975
and cables:
http://www.kenable.co.uk/index.php/c...243928c10bd975
would be better to use with the option of what system you like.
Hope this helps
Chilly Willy is offline
Old 11-02-2008, 5:17 PM   #5 (permalink)
Thanks: Gave 31, Got 243
Just thought I'd point out that the Yamaha AV-3101 is sold as the AV61 here in the UK; basically a package of the RXV361 av receiver and NSP110 surround speaker package). The black version isn't sold here in the UK though.
However, based on your requirements it sounds like it may be worth you seeking out the Sony HTSS1200 (- 3 hdmi switched inputs able to take both sound and video for use with the PS3 and HD-EP30, hdmi plus optical input carrying surround sound for Sky HD plus a spare coax digital input). Stocks seem quite hard to find right now though - try your local Sony centre.
Robert
Panasonic TH37PX70 TV ~ Panasonic PT-AE100E Projector ~ Yamaha RXV1700 AV Receiver ~ Momitsu DVD-V880 DVD ~ Toshiba HD-D1 ~ Canton Movie 150-QX speakers ~ PS3 (Japanese) ~ XBOX 360
rwniel is offline
allinone, budget
[IMG] code is Off
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Budget, Budget, Budget, what was your budget & then how much did you end up spending? meizumintyboi Computer Systems 2 05-09-2007 3:45 PM
Budget Plasma, Budget Performance? gargoyle Plasma Televisions 2 31-12-2006 3:07 PM
Budget day dc007 General Chat 202 26-03-2006 2:41 PM
Which budget receiver - Budget £200 to £250 50/50 Integrated AV Amplifiers and Receivers 3 29-04-2005 10:30 PM
Go budget Flashback666 PC Games 2 26-03-2004 12:27 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
